Cam Degreeing
https://slantsix.org/forum/viewtopic.php?t=27764
Page 2 of 2
Author:  Joshie225 [ Tue Mar 18, 2008 10:17 pm ]
OK, but don't goof and check the #1 exhaust while trying to find the intake centerline. Done that, wasted some time figuring out how it could be so far off.
Author:  emptypockett [ Wed Mar 19, 2008 12:37 pm ]
Post subject:  Timing Gears
Well I searched and contacted JP Preformance.They didn't get back to me.I ordered gears and chain from Rollmaster(I bought one of their balancers,nice piece).There lower crank gear for the Slant Six has 9 keyways cut in it! Should be able to degree the cam in perfectly with that.Lou posted and thought that 108 was to much.We had a custom cam ground just for this engine factoring in comp,rpm,head volume,valves,trans gears ect...I gotta go with what they want.I'm not going to have it Dyno'd.Going to put it in and have it chassis dyno'd because a guy in town has one and we'll tune it there.As always you guys steered me in the right direction.Keep you posted,Paul :D
Author:  Dart270 [ Wed Mar 19, 2008 1:27 pm ]
What are your cam specs?
Author:  polara pat [ Sat Mar 22, 2008 11:38 am ]
This is a blatant high-jack but it's really on topic. I was just sorting out my degree #s and it seems really low. Maybe I'm out to lunch on my procedure. Here it goes. Find true TDC; set up the dial indicator on the valve train; zero dial at max. lift and take a reading @ .050 on either side of 0. Add them together and divide by two. This should be the # I'm looking for. My #s were 45 and 139. This comes out to 87. Where did I go wrong.
OK, so you're doing the intake centerline method. Fine. Are you checking #1's intake or exhaust? If that's 87° ATDC I think you're a tooth advanced.
My fourth check revealed that I was in fact out a tooth on the chain. You are the winner of my diagnosis, thanks. that puts me at 106* which seems like good place to be.
Author:  emptypockett [ Wed Mar 26, 2008 7:54 am ]
Post subject:  Degreeing Cam
Well I recieved a gear set and chain from Rollmaster and the motor man call me yesterday to tell me what a great piece it was and that it's all degreed in.I'll post the cam specs for Lou when I get the cam card.Motors almost done but the car won't be going to Vegas.I'm going anyways and hoping to hook up with some fellow slanters.Will there be an area for the slant crs?Or just walk around and look for them. really depreed I can't bring my car but yhey'll be other reaces.I'll post some pic next week.Thanks and look forwards to meeting some of you,Paul :wink:
Author:  Dart270 [ Thu Mar 27, 2008 7:08 am ]
Glad that worked out. What did he degree it at?
Pat, 106 is too far retarded for just about any Slant cam. 103 is my personal max for anything I would install, and 100 is more like it for a perf cam. MANY racers have died (lost 1-4 tenths) to bring you this info... :lol:
Page 2 of 2 All times are UTC-07:00
