It is currently Wed Nov 25, 2026 10:02 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Tue May 20, 2008 9:18 pm
I hate to tell you this, but XV's rack and pinion is a Mustang II rack. It's a good rack, but strictly off the shelf stuff.
"Aluminum Variable Rate Quick Ratio Power Rack & Pinion Steering"
Call them and ask.
restomodchallenger.com
PostPosted: Tue May 20, 2008 9:54 pm
Please Let me clarify: the XV level II front suspension kit contains a mustang II rack and pinion.
The kit you are talking about, the level I kit, does not offer steering components. Since they don't sell anything for your car this is a moot point.
Front Suspension now $2,395.00
XV Custom Valved Aluminum Body Monotube Shock Absorbers - 100% Dyno Tested
XV Spec Torsion Bars (Small Block & Big Block Rates)
XV Spec Front Anti-Roll Bar w/End Links & Urethane Bushings
XV Billet Front Anti-Roll Bar Mount
XV Adjustable Strut Rod
Urethane Strut Rod Bushings
Urethane Upper & Lower Control Arm Bushings
Rear Suspension
XV Custom Valved Aluminum Body Shock Absorbers - 100% Dyno Tested
XV Spec Leaf Springs
Urethane Leaf Spring Bushings
New Leaf Spring Shackles & Bolts
XV Spec Rear Anti-Roll Bar w/End Links & Urethane Bushings
I see $1,400 worth of parts max. Let's put the XV conversation to rest.
