| XV Level 1 https://slantsix.org/forum/viewtopic.php?t=28836 |
Page 2 of 2 |
| Author: | resotmodchallenger [ Tue May 20, 2008 9:18 pm ] |
I hate to tell you this, but XV's rack and pinion is a Mustang II rack. It's a good rack, but strictly off the shelf stuff. "Aluminum Variable Rate Quick Ratio Power Rack & Pinion Steering" Call them and ask. |
| Author: | resotmodchallenger [ Tue May 20, 2008 9:54 pm ] |
Please Let me clarify: the XV level II front suspension kit contains a mustang II rack and pinion. The kit you are talking about, the level I kit, does not offer steering components. Since they don't sell anything for your car this is a moot point. Front Suspension now $2,395.00 XV Custom Valved Aluminum Body Monotube Shock Absorbers - 100% Dyno Tested XV Spec Torsion Bars (Small Block & Big Block Rates) XV Spec Front Anti-Roll Bar w/End Links & Urethane Bushings XV Billet Front Anti-Roll Bar Mount XV Adjustable Strut Rod Urethane Strut Rod Bushings Urethane Upper & Lower Control Arm Bushings Rear Suspension XV Custom Valved Aluminum Body Shock Absorbers - 100% Dyno Tested XV Spec Leaf Springs Urethane Leaf Spring Bushings New Leaf Spring Shackles & Bolts XV Spec Rear Anti-Roll Bar w/End Links & Urethane Bushings I see $1,400 worth of parts max. Let's put the XV conversation to rest. |
| Page 2 of 2 | All times are UTC-07:00 |
