2 barrel carb on single barrel manifold
https://slantsix.org/forum/viewtopic.php?t=28966
Page 2 of 2
Author:  Adrenalin [ Mon May 19, 2008 10:36 pm ]
Forum: Engine Posted: Sat Jun 16, 2007 8:51 am Subject: manifold adapter?
Here's my modified 1 bbl
That is exactly what I am planning. To machine the current manifold and install a two barrel adapter but I am planning to bolt the adapter since I think that welding can deform the manifold. did you have any deformation issues? Also When I check the manifold for two barrels I see that the throttle pin is perpendicular to the engine. You have made it parallel. Is there any special reason for that? I live in turkey so it will be really hard for me to ship a manifold to my address :)
Looking forward to your reply.
Sincerely yours,
Author:  61 V200 [ Tue May 20, 2008 1:07 pm ]
1. Cast iron manifold. No deformation issues.
2. My 61 has solid throttle linkage. The rotation of the shaft has to be reversed for the bbd.
I could have changed to a cable type linkage but I opted not to. Also, in theory you should get better distribution of the fuel with the throttle plates running parallel to the intake runners
Author:  Adrenalin [ Tue May 20, 2008 10:20 pm ]
Mine has cable linked, it is not a problem for me to rotate the carb but I also heard the distribution is better in this (parallel) way. Did you feel any performance increase?
By the way, you have been a great help. Thank you for clarifying dark clouds over me :)
Author:  GFFM [ Fri May 23, 2008 8:35 am ]
[quote="SlantSixDan"]61V200, I still say that's first-class work you did.
Did anyone else see the one that went by on eBay last month? Somebody got a deal...was it one of us here?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0237088437[/
quot
Yes, it was one of us here! A newbe, I've been lurking in the background for a couple of years reading a lot of these interesting posts. After buying this manifold I decided that I had to join; in order to get some suggestions/help on how to utlize this manifold.
Application: 85 Dodge 150
727 trans
3.55 gears
My questions, has anyone suggestions on a carb to use and what do I use for a trans kickdown assy.
Page 2 of 2 All times are UTC-07:00
