Slant Six Forum https://slantsix.org/forum/ |
My '63 Valiant Project https://slantsix.org/forum/viewtopic.php?t=29107 |
Page 2 of 2 |
Author: | armyofchuckness [ Fri Aug 29, 2008 5:57 pm ] |
Post subject: | |
It lives! What a great feeling. I remember the first time my 64 turned over and kept running. It had been sitting for at least three years. Probably more given the flat and rotten tires. I'm quite happy for you. I'm also amazed that your e-brake worked. Mine was rotten clean through...along with the brake lines themselves. Maybe this car was sitting longer than I thought. |
Author: | Useless [ Sun Aug 31, 2008 6:33 am ] |
Post subject: | |
Quote: Quote: Haha, I think that's just about the most solid mechanical part I've got on the car right now! Well....other than the new dizzy and fuel pump..
Well, good luck with your car! Those rear lower quarters behind the wheel look like loads of fun... We'll have to make the strip for sure Lou, I've been up there and watched a few times but never been down the track. |
Author: | Useless [ Sun Aug 31, 2008 6:42 am ] |
Post subject: | |
Quote: It lives! What a great feeling. I remember the first time my 64 turned over and kept running. It had been sitting for at least three years. Probably more given the flat and rotten tires.
Luckily this car spent about 8 of the 10 years it sat on a paved lot and a local Ford dealership, after that it was moved to gravel lot, I used to drive by and "look at that crazy Valiant" every week in my Coronet after leaving the local cruise in. I'm quite happy for you. I'm also amazed that your e-brake worked. Mine was rotten clean through...along with the brake lines themselves. Maybe this car was sitting longer than I thought. Not having any grass growing up underneath and getting the bottom side wet helps a lot, my floor pans are pretty much perfect other than surface rust on the inside due to leaky wiper pivot seals and back window. It also didn't have factory undercoating thank goodness; I've had 20+ mopars and the only ones that had solid floors were the ones that didn't have undercoating. |
Page 2 of 2 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
