| third brake lamp https://slantsix.org/forum/viewtopic.php?t=29286 |
Page 2 of 2 |
| Author: | 66aCUDA [ Thu Jun 05, 2008 12:08 pm ] |
Hum Thanks Dan Im wondering if the light wieght plastic halogen bulbs wont be better??? Frank |
| Author: | SlantSixDan [ Thu Jun 05, 2008 1:18 pm ] |
Well, again, it depends. What's your power consumption limit? Size/shape limitations? |
| Author: | Ron Parker [ Thu Jun 05, 2008 6:27 pm ] |
Sorry not to get back quicker. Yes the rear light I want would be behind the back glass like a third light. Cant use tail lites for another reason. Dan is the third light led on your site is all I need or do I need a power pak. I want something I can turn on and make a run then turn off. But me being a dumb butt if I was to leave it on a while it would not damage it. Thanks Ron Parker I Might See The Lite But It Aint Over Until I Win |
| Author: | SlantSixDan [ Thu Jun 05, 2008 8:15 pm ] |
You could run these all day and all night and after a lonnnnng time your battery would run down, is all. The 3rd brake lights on my site are meant to be run off the car's battery and/or electrical system. Just hook it up to any 12-14v source and it'll be fine. |
| Author: | 66aCUDA [ Fri Jun 06, 2008 6:27 am ] |
Dan Size and shape limits... I would guess I would mount mine in the space the old headlights were in. Power consumption 5 amps or less would be great. Also a switch to control it. For some reason the switchs seem to be junk today also.HUMMM Thanks Frank |
| Author: | SlantSixDan [ Fri Jun 06, 2008 8:31 am ] |
Well, what's in the headlamp space now? Some kind of blockoff plate? Can't imagine it's an uncapped "sugar scoop" hole (bad aerodynamics). If it is a blockoff plate, make the necessary hole in it and put that round LED reversing lamp in that I linked to above. Switches off the shelf from most auto parts stores are Chinese garbage (big surprise) these days, but good switches can be had. What kind do you want? |
| Author: | Ron Parker [ Fri Jun 06, 2008 3:22 pm ] |
Thanks Dan I will pm you thanks Ron Parker It Aint Over Until Everybody Sees The Rear Lite |
| Author: | 66aCUDA [ Sat Jun 07, 2008 3:02 am ] |
Dan I guess either SPST OR DPST non iluminated. Nothing fancy, sent you a pm. Thanks Frank |
| Author: | SlantSixDan [ Sat Jun 07, 2008 9:23 am ] |
Got your PM about the carburetors (working on it). Was there a separate one about switches and lights? |
| Page 2 of 2 | All times are UTC-07:00 |
