| A/C is working on the 68! Few questions though....... https://slantsix.org/forum/viewtopic.php?t=29457 |
Page 2 of 2 |
| Author: | SlantSixDan [ Thu Jun 12, 2008 1:58 pm ] |
Quote: My exp valve was not going to fit with everything else that was new anyway, if it had fit I would have used it. I sold it on ebay to a guy with a Cuda who was very happy to get an original and correct valve. Otherwise I would have tried adjusting it just a little and see what happened.
So...what are you using instead?
| Author: | ValiantOne [ Thu Jun 12, 2008 2:15 pm ] |
Quote: Quote: My exp valve was not going to fit with everything else that was new anyway, if it had fit I would have used it. I sold it on ebay to a guy with a Cuda who was very happy to get an original and correct valve. Otherwise I would have tried adjusting it just a little and see what happened.
So...what are you using instead?I'll tell ya, if the old r12 valve isn't optimum, it is sure working pretty good in my car. It was only 80* ambient the other day though. I am wondering how it will do on a really hot and humid day. I won't have to wait long to find out! |
| Author: | SlantSixDan [ Thu Jun 12, 2008 2:28 pm ] |
Yeah...I would say your next step wouldn't have anything to do with the system itself, but would focus on reducing the system's workload by means of good quality window tinting (not the cheap film that turns purple in a couple years) and better insulation. |
| Author: | Charrlie_S [ Thu Jun 12, 2008 3:00 pm ] |
Quote: As far as the valve goes, it can be swapped for the less elegant type with a single bulb that just gets attached to the evaporator outlet and insulated.
There are two basic types of expansion valves, the externally equalized (which has the pressure sensing line that goes to the outlet of the evaporater, and the internal equlalized, which sensis the evap pressure on the inlet of the evap. The purpose of the expansion valve is to meter the refrigerant into the evaporator, to maintain a "almost flooded evap". it does this by comparing pressure and temp of the refrigerant. The externally sensed valve is better at controlling this, because it senses the presure and temp at essentially the same place in the system. The adjustment in the end of the valve is to adj the "superheat". It does not adj pressure. Every A/C evap needs a certain amount of superheat to allow the coldest evap possible, with out allowing liquid refrigerant to get back to the compressor.I looked real close at the original valve and the pressure is adjusted / calibrated by simply using an allen wrench inserted into the outlet. One would have to set up some sort of test set off car and, I assume, use compressed air or better yet dry nitrogen. The sensor bulbs temperature would need to be controlled during calibration, maybe immersed in water. In the end the goal would just be to drop the pressure something like 4 or 5 psi., so maybe it would just need to be adjusted that many psi from point A to point B without getting too fancy. Perhaps some trial and error could result in a "rule of thumb" amount to turn the adjustment? Just so long as it does not end up too low and cause frost problems. My exp valve was not going to fit with everything else that was new anyway, if it had fit I would have used it. I sold it on ebay to a guy with a Cuda who was very happy to get an original and correct valve. Otherwise I would have tried adjusting it just a little and see what happened. Dan, as for the regulation about HP coutoff switches. I don't know where to look that up, maybe on the EPA website, about retrofits. It might be listed in the same place that says, any system retrofitted to a refrigerant that contain R-22, must use "barrier" style hoses. I learned this stuff going to different schools and training sessions, but that was maybe 15 years ago. I have been to numerous "schools", on A/C and refrigeration. PS I am certified under part 608 and 609. |
| Author: | AnotherSix [ Thu Jun 12, 2008 4:33 pm ] |
Well, so much for making changes to the original valve. Thanks for clearing that up. As far as what valve I am using, it is the internally equalized type. All my underhood plumbing is new and there is nowhere to connect the old valves pressure line. Sure I could have a fitting welded on to the suction hose fitting, but I just decided to keep it simple with a valve set for r134. I am using a sanden as well. |
| Author: | Bren67Cuda904 [ Thu Jun 12, 2008 4:49 pm ] |
Quote: Quote: As far as the valve goes, it can be swapped for the less elegant type with a single bulb that just gets attached to the evaporator outlet and insulated.
There are two basic types of expansion valves, the externally equalized (which has the pressure sensing line that goes to the outlet of the evaporater, and the internal equlalized, which sensis the evap pressure on the inlet of the evap. The purpose of the expansion valve is to meter the refrigerant into the evaporator, to maintain a "almost flooded evap". it does this by comparing pressure and temp of the refrigerant. The externally sensed valve is better at controlling this, because it senses the presure and temp at essentially the same place in the system. The adjustment in the end of the valve is to adj the "superheat". It does not adj pressure. Every A/C evap needs a certain amount of superheat to allow the coldest evap possible, with out allowing liquid refrigerant to get back to the compressor.I looked real close at the original valve and the pressure is adjusted / calibrated by simply using an allen wrench inserted into the outlet. One would have to set up some sort of test set off car and, I assume, use compressed air or better yet dry nitrogen. The sensor bulbs temperature would need to be controlled during calibration, maybe immersed in water. In the end the goal would just be to drop the pressure something like 4 or 5 psi., so maybe it would just need to be adjusted that many psi from point A to point B without getting too fancy. Perhaps some trial and error could result in a "rule of thumb" amount to turn the adjustment? Just so long as it does not end up too low and cause frost problems. My exp valve was not going to fit with everything else that was new anyway, if it had fit I would have used it. I sold it on ebay to a guy with a Cuda who was very happy to get an original and correct valve. Otherwise I would have tried adjusting it just a little and see what happened. Dan, as for the regulation about HP coutoff switches. I don't know where to look that up, maybe on the EPA website, about retrofits. It might be listed in the same place that says, any system retrofitted to a refrigerant that contain R-22, must use "barrier" style hoses. I learned this stuff going to different schools and training sessions, but that was maybe 15 years ago. I have been to numerous "schools", on A/C and refrigeration. PS I am certified under part 608 and 609. I'd also like to add that if your expansion valve is external psi sensing, the psi sensing tube must be hooked up and can not be plugged. |
| Author: | ValiantOne [ Fri Jun 13, 2008 5:29 am ] |
Guys this is great info. Thank you. So if I wanted to get rid of the oem expansion valve with all of the associated capillary tubes to "clean things up" under the hood, and get an actual 134a compatible valve, I could: 1) find a way to plumb a 134a internal sensing exp valve into the the high pressure line at the firewall. 2) plumb in a external sensing pressure valve for 134a, assuming there is such an animal. (I'm not sure there is going off of what Bren67 said) ?? Is that about right? |
| Author: | SlantSixDan [ Fri Jun 13, 2008 7:10 am ] |
Quote: So if I wanted to get rid of the oem expansion valve with all of the associated capillary tubes to "clean things up" under the hood
I wouldn't do this, if I were you. The OE expansion valve works very well, and...really, now, does its appearance bother you that much?Quote: 1) find a way to plumb a 134a internal sensing exp valve into the the high pressure line at the firewall.
You could put in an H-style (block) valve if you really wanted to. They make them with threaded fittings. But it'd involve a lot of tube, fitting, and flange reworking, and for what real benefit? Again, I think you'll see a much larger, more cost-effective improvement in system performance by going in for some quality window tinting (I like the Llumar films; I've had 'em on the Lancer and the 164 for years and they've held up very well).I'd also look at insulating the space between the headliner and the metal roof panel, and the next time you've occasion to pull up the carpet, improve the insulation there, too, and behind the back seat. I'm still coming up zero looking for R134a-specific expansion valves. The 1977 Dodge Aspen and 1991 Dodge Spirit (w/R12) and the 1999 Dodge Neon and numerous other models (w/R134a) all use the same block-style expansion valve, a Four Seasons #38849. OK, that's aftermarket, but the '91 Spirit (w/R12) and the '95 Spirit (w/R134a) also got the same expansion valve (#4176 999) from the factory. So I really wouldn't spend too much time or effort chasing down an R134a-specific expansion valve. |
| Author: | ValiantOne [ Fri Jun 13, 2008 7:24 am ] |
Quote: Quote: So if I wanted to get rid of the oem expansion valve with all of the associated capillary tubes to "clean things up" under the hood
You could put in an H-style (block) valve if you really wanted to. They make them with threaded fittings. But it'd involve a lot of tube, fitting, and flange reworking, and for what real benefit? Again, I think you'll see a much larger, more cost-effective improvement in system performance by going in for some quality window tinting (I like the Llumar films; I've had 'em on the Lancer and the 164 for years and they've held up very well).I'd also look at insulating the space between the headliner and the metal roof panel, and the next time you've occasion to pull up the carpet, improve the insulation there, too, and behind the back seat. Funny you should mention the insulation. Right now the car doesn't have any carpet or jute in it. I am getting it ready to weld in the subframe connectors, which I aim to pick up from US Cartool at Carlisle this year. Without the carpet and the jute, that floor gets HOT!!! Dan this may be a stupid question, and sligthly off topic for the thread, but I always wondered why tinting windows a dark color would cool the inside of the car, rather than absorb heat and make it hotter. ?? Thanks CE |
| Author: | SlantSixDan [ Fri Jun 13, 2008 8:02 am ] |
It does seem counterintuitive, but the dark appearance is only one part of what's going on. There is an enormous range of different tint films on the market. Depending on the dyes and/or metallic coatings in and on the film, they block various levels of visible light, UV (which causes fading of interior materials) and/or infrared (=heat). If you go for window tinting, it's worth buying one of the relatively expensive high-tech metallised films. Mouse around on the Llumar site I linked; they have a pretty good PDF that gives the specs on a bunch of their films. |
| Page 2 of 2 | All times are UTC-07:00 |
