| Larger Tranny Pan https://slantsix.org/forum/viewtopic.php?t=29772 |
Page 2 of 2 |
| Author: | Charrlie_S [ Sun Jun 29, 2008 5:18 am ] |
Quote: Quote: Quote: I have raced my car w/o that spacer in it for a long time and nothing happened.
Then why bother with a deep pan? I use a deep pan, with the extended pickup, and run the fluid at the add fluid mark, hot.PS: if I am not mistaken TFpatty has the dropped spacer for the dual pump transmissinons. I can use the singel pikup in my early trans, as I have a manual VB, and the rear pump removed. Not ragging on you, just asking questions, and discussing this to learn. When I was 16 I knew everything, now at 66, I have forgotton a lot. |
| Author: | slantzilla [ Sun Jun 29, 2008 9:44 am ] |
C'mon Charlie, you know this. Nitrous+loose converter+trans brake=you need all the fluid capacity you can get to keep from cooking a converter. |
| Author: | Charrlie_S [ Sun Jun 29, 2008 5:16 pm ] |
My Valiant doesn't have a trans temp gauge, but my Cuda has never seen over 180 degrees at the track. I have seen about 210 on the street after a 100 mile drive, with the 8 in converter. |
| Author: | 63dartdude [ Sun Jun 29, 2008 10:15 pm ] |
| Post subject: | Larger Tranny Pan |
Thanks for all your help. I took the spacer to a machine shop, and he did great, since I also gave him the filter to work with. I got it all put together, and it works fine. I appreciate all the help. |
| Page 2 of 2 | All times are UTC-07:00 |
