| f-body rearend swap https://slantsix.org/forum/viewtopic.php?t=30643 |
Page 2 of 3 |
| Author: | Hellrazor [ Wed Nov 05, 2008 5:41 pm ] |
UPDATE! After about three months of waiting and searching i finally got my hands on an 8 1/4 from an m-body station wagon with 3 speed auto and a 318, i took off the cover when i got it home but i couldn't find out the gear ratio, shouldn't it be stamped on the ring gear? So my question for anyone reading this is... what kind of gear ratios did m-body station wagons get when equipped with a 318 and auto trans ? I found a tag on one of the cover bolts but all that is written on it is "1406" For the love of god i hope it ain't one of those 2.45 ratio units, they wouldn't have been cruel enough to use such a wimpy gear in a wagon right? |
| Author: | THOR [ Thu Nov 06, 2008 12:24 am ] |
It's easy to figure out what the ratio is. It should be stamped on the ring gear, and it seems odd that yours isn't. IIRC, the ratio should also be stamped on the housing around the carrier somewhere (or is that only 7.25"?). If nothing else, grab some chalk, and do the old "How many turns of the pinion does it take to make 1 revolution of the ring gear?" trick. ~THOR~ |
| Author: | Doc [ Thu Nov 06, 2008 10:52 am ] |
Count the teeth in the ring and pinion gears, divide the ring gear tooth count by the pinion number. Example: 44 / 18 = 2.44444 or 47 / 17 = 2.7647 DD |
| Author: | Hellrazor [ Thu Nov 06, 2008 11:49 am ] |
Will do! thanks Doc. THOR: Yeah i cleaned her up real nice and still couldn't find it, so i'll go ahead and start counting those teeth. |
| Author: | Hellrazor [ Thu Nov 06, 2008 9:06 pm ] |
Whoa! hold on a minute, i counted 47 teeth on the ring gear but 21 on the pinion 47/21 = 2.2380 so unless i miscounted the teeth (checked three times) that means my ratio is 2.23 I'll probably check again tomorrow in the daylight for the hell of it but providing the ratio realy is 2.23 can it be changed? or is this rear end like the 2.45 carrier units that can't have the gears swapped. |
| Author: | volaredon [ Fri Nov 07, 2008 5:59 am ] |
Very well could be; my buddy had an 81 mirada, 318, 8-1/4 rear and it was a 2.2x ratio. Also my Moms 84 5th had that ratio (at least its not a 2.45 |
| Author: | Hellrazor [ Fri Nov 07, 2008 6:08 am ] |
Well doing a little more digging around this great site, i found some posts mentioning 2.24 and 2.45 carrier units being incompatible with any lower gear sets. All though some posts lead me to believe i can swap in a carrier from a 94 and down truck 8 1/4 then use what ever gear set i choose, anyone know if this has been done before? |
| Author: | volaredon [ Fri Nov 07, 2008 3:55 pm ] |
Yup; common swap; except that the highest year I believe is a 96 dakota not 94. Lots of B vans used that rear end too; just knock the "exciter ring" off, that triggers the ABS brakes; while it won't hurt anything; there may or may not be clearance in your older housing for it. |
| Author: | Hellrazor [ Fri Nov 07, 2008 6:14 pm ] |
Groovy. |
| Author: | Hellrazor [ Sun Nov 16, 2008 7:14 pm ] |
| Post subject: | cuttin' down the driveshaft |
Well the swap is nearing completion, found a carrier with new ring and pinion 3.21 So providing i can't find a stock replacement, how much does the 7 1/4 shaft have to be cut down for an f-body ? i read some were that 1.6" has to be taken off but that was in regards to a 74 Dart. |
| Author: | volaredon [ Sun Nov 16, 2008 8:36 pm ] |
sounds about right; I did a 7-1/4 to 8-1/4 swap in a 90 Dakota and that #cut off the shaft sounds about right. It don't matter the chassis; any time you go from a 7-1/4 to an 8-1/4 (unless you're also changing to a different model tranny too) in a given vehicle that number is gonna stay constant. |
| Author: | Hellrazor [ Sun Nov 16, 2008 10:08 pm ] |
Good stuff thanks man. Can't wait to get this puppy back on the road and see what the new gears are like. |
| Author: | NewSlanter [ Fri Nov 21, 2008 6:54 pm ] |
When I swapped out my 7¼ for an 8¼I had the shop take off 7/8". I found that # here somewhere, but I'm not too sure where. Mind you, my car is a '70 dart, but it should still be the same change. Nat |
| Author: | Hellrazor [ Sat Nov 22, 2008 7:43 pm ] |
Well a few days ago i had it shortened 1.6" and after i got it home and installed a new u-joint , i stuck her in there and it seemed to fit just like it did when hooked up to the old 7 1/4 rear. The 3.21 gear set is real nice for this heavy old f-body. |
| Author: | Volare4life [ Sat Feb 07, 2009 11:01 am ] |
hell razor, check out [url]moparstyle.com[/url] go to the FMJ Body section and look for my post on "rear end ID ". if your still slant powered, I would reccommend sticking with a 8 1/4", 8 3/4" is over kill in my book. I too own a F-body, '79 Volare 2dr, so I know how difficult info can be to find sometimes. remember any FMJ part from '76-'89 will interchange with your car. If you have any questions please feel free to ask -Mike |
| Page 2 of 3 | All times are UTC-08:00 |
