Hard Starting on Warm Engine - 74 swinger
https://slantsix.org/forum/viewtopic.php?t=30686
Page 2 of 2
Author:  74DartSport [ Mon Aug 25, 2008 4:32 pm ]
Platinum plugs are generally not money well spent on a slant-6 engine. Instead, take advantage of the fact that you have a pre-1975 engine and use the NGK #ZFR5N extended-nose spark plugs. Remember to remove the metal ring washer from each plug before installing it.
I have seen this suggestion to remove the metal ring washer from the sparkplugs in other posts. Can someone explain what this procedure does.
Author:  SlantSixDan [ Mon Aug 25, 2008 6:39 pm ]
See here.
Page 2 of 2 All times are UTC-07:00
