T-5 Guys, Question
https://slantsix.org/forum/viewtopic.php?t=30751
Page 2 of 2
Author:  vynn3 [ Fri Aug 29, 2008 10:34 am ]
HI Vynn,
I will have some write ups on this subject in the article, but would you be surprised to hear that you can weld up your own with two 3" by 36" 3/16 pieces of steel from Lowes? That the only tools you need are a welder, a couple of jacks ( one to hold the tranny in place, one to help you bend the steel where you want), a drill, and a 1/2 bit, and a chopsaw ( you can use a hacksaw, but you will be there all day).
It isn't hard. I tried three different approaches, and discovered the best way was to use the car itself as a jig, and weld it up to the car.
I will write this up more when I get a chance. building your own crossmember isn't that bad.
Thanks, Greg. I'm trying to be a good boy and not pester you guys about the detailed article you're working on, and like I said, it's not like I plan on doing the conversion next week. It's just that, the more money I invest in parts for the project, the closer I get to the point of no return... (if I'm not already there). I know I could probably sell the bellhousing and all of the stuff I've gathered and make back some of the dough if I decide I'm in over my head, but I'm really not wealthy enough to take much of a financial loss. So, I guess I'm just trying to reassure myself that I CAN do this when I'm ready.
I REALLY appreciate you T-5 conversion experts helping "fabrication-challenged" idiots like me try to make this work, and look forward to any future insights you guys can provide.
Author:  NewLancerMan [ Fri Aug 29, 2008 11:37 am ]
Vynn, of all the folks that have done this conversion, I am the least experienced of all of them. I know where you are coming from and I am trying to line up my ducks as well. However, with the help of everyone here, it can be done, and you can do it. Don't fear.
BTW the crossmember pics I posted are of the one Greg made, as well as Lou's and 64$peed's
MJ
Author:  Dart270 [ Fri Aug 29, 2008 11:45 am ]
Post subject:  It's not that hard
Made the lower X using a stock one with some minor mods using 13 ga steel sheet. I had done very little welding before.
The upper X was bolt in that my TIG buddy Mike Roy in CA did for me starting with cardboard patterns I made. Since then, I MIG welded in a similar upper X on the '68 Dart (A500 trans swap) using 1X2" box tubing and it has been fine. That's what I would do on the '64 if doing the T5 now.
Author:  vynn3 [ Fri Aug 29, 2008 1:16 pm ]
Thanks so much, guys!
Author:  64'4$peed [ Sun Aug 31, 2008 3:34 pm ]
easiest to do on the car. I fabbed one up from scratch but had to drive a couple blocks to weld anything. could have saved time if I had a welder at home. maybe someday I'll get one. feel free to PM any specific questions.
Page 2 of 2 All times are UTC-07:00
