| shocks...smooth ones... https://slantsix.org/forum/viewtopic.php?t=31200 |
Page 2 of 2 |
| Author: | Joshie225 [ Thu Sep 25, 2008 9:31 pm ] |
Quote: I dont think any set of shocks is going to compensate for the stiff spring rates I'm using.
What torsion bars are you running?
| Author: | THOR [ Thu Sep 25, 2008 9:37 pm ] |
Quote: Quote: I dont think any set of shocks is going to compensate for the stiff spring rates I'm using.
What torsion bars are you running?~THOR~ |
| Author: | Joshie225 [ Thu Sep 25, 2008 9:48 pm ] |
I figured as much, but I was asking Mr. 64 4-speed. |
| Author: | Patrick Devlin [ Fri Sep 26, 2008 3:08 am ] |
Edelbrock IAS shocks are my favorite right out of the box. I like how they soften up on impact, but do the job on rebound. On my Dart, I have .920" t-bars and the Edelbrocks. |
| Author: | 64'4$peed [ Fri Sep 26, 2008 7:22 am ] |
I've got .890's it's not unbearably stiff or anything. but its no lincoln town car. I've also got poly everything in the front end. |
| Author: | Joshie225 [ Fri Sep 26, 2008 7:44 am ] |
.890, is that all? I'm running 1.04' torsion bars and it rides very well. The dampers (shock absorbers) are the key. |
| Author: | Guest [ Fri Sep 26, 2008 8:25 am ] |
Quote: .890, is that all? I'm running 1.04' torsion bars and it rides very well. The dampers (shock absorbers) are the key.
Wow wicked, do you have super expensive shocks?
| Author: | Joshie225 [ Fri Sep 26, 2008 9:47 am ] |
I have QA1 Stocker Star single adjustable dampers. Not cheap, but good shocks are necessary with high rate springs. |
| Author: | vynn3 [ Fri Sep 26, 2008 10:48 am ] |
Quote: I have QA1 Stocker Star single adjustable dampers. Not cheap, but good shocks are necessary with high rate springs.
And they're rebuildable, too. So they pay for themselves over, what, 40-50 years? That's what I plan on running next. |
| Author: | NewLancerMan [ Fri Sep 26, 2008 12:43 pm ] |
vynn you kill me. =) I can tell you this, I did some before/after rides in a friend's cuda with a poly front, .990 tbars and KYBS vs. the SPAX. I can't even compare the difference. At speed, the KYBS were just plain harsh over bumps. The SPAX were far better at making the ride smooth. More sportscar vs. towncar smooth, but very nice to ride in. MJ |
| Author: | Guest [ Fri Sep 26, 2008 1:32 pm ] |
Quote: I can tell you this, I did some before/after rides in a friend's cuda with a poly front, .990 tbars and KYBS vs. the SPAX. I can't even compare the difference. At speed, the KYBS were just plain harsh over bumps. The SPAX were far better at making the ride smooth. More sportscar vs. towncar smooth, but very nice to ride in.
SPAX?
| Author: | NewLancerMan [ Fri Sep 26, 2008 2:48 pm ] |
They are an English damper, and I organized a group buy on them about 2 years back. you can buy them from http://jrponline.com but like I said, they ain't cheap. They are single adjustable with 20 some odd damping settings. Lou and maybe Josh have a set. I can't recall, I organized it on the mopax list. MJ |
| Page 2 of 2 | All times are UTC-07:00 |
