| crank trigger signal for GM Sequential FI https://slantsix.org/forum/viewtopic.php?t=3184 |
Page 2 of 2 |
| Author: | Loghead [ Mon Feb 04, 2002 5:08 pm ] |
| Post subject: | Re: Need cam position sensor for GM Sequential FI |
: You're right; the mid 80's batch fire set-ups : are getting hard to find in the pick-a-part : yards. These yards like to crush the old : cars and get newer ones as soon as possible. : That's where they make the most money. : The good news is that I'm quite sure you can : use some of these newer sequential set-ups : as batch fire systems in a SL6 with a : distributor. I think you can do this, even : though they are sequential, because I : believe they will default to batch fire with : the lack of a cam sensor signal. I want to : emphasize that I haven't completely verified : this yet. I do plan on getting one of these : ECMs and trying it when the good weather : returns. : What I do know is that when I substituted the : sequential ECM from a turbo Regal for my : batch fire ECM, it run well except under : heavy acceleration. The turbo ECM expected : to see higher flowing injectors than I now : have, so I think that was probably the : problem. I'm speculating that ECM provided a : pulse width to the injectors (based on the : MAF signal) that would have supplied enough : fuel with the larger injectors, but not : enough with my smaller injectors. : Bob D I found the following web page , which you may have seen already. These position sensors don't appear to be as complicated as I had once imagined. It may be possible to use the distributor as a means of cam position sensing, particularly if one were willing to use a GM ignition module(eliminating centrifugal advance) and putting the sensor in the space the centrifugal advance mechanism now occupies. It's just a thought , perhaps a very weird thought, but I'm trying to think "out of the box" as they say. http://www.kemparts.com/TechTalk/tt10.asp thelogs@cox.net |
| Author: | Bob D [ Tue Feb 05, 2002 4:53 pm ] |
: I found the following web page , which you may : have seen already. These position sensors : don't appear to be as complicated as I had : once imagined. It may be possible to use the : distributor as a means of cam position : sensing, particularly if one were willing to : use a GM ignition module(eliminating : centrifugal advance) and putting the sensor : in the space the centrifugal advance : mechanism now occupies. It's just a thought : , perhaps a very weird thought, but I'm : trying to think "out of the box" : as they say. Keep at it! If you could mount a sensor in the distributor somewhere off of the centrifugal advance plate, it would be independent of the ignition timing, and could be used to sequence your injectors. Bob D BBobbias@aol.com |
| Author: | Bob D [ Tue Feb 05, 2002 4:56 pm ] |
: serv. no. 1228253 : I'll take any info you can get. : -qwimby Sorry, I couldn't find any information on that ECM. Because of the 8XXX ending my guess is that it's from 1989 or the early 90's. Bob D BBobbias@aol.com |
| Author: | Qwimby [ Tue Feb 05, 2002 6:28 pm ] |
should be out of a 1988 oldsmobile something Quote:
: : Sorry, I couldn't find any information on that : ECM. Because of the 8XXX ending my guess is : that it's from 1989 or the early 90's. : Bob D cratsmarx@hotmail.com |
| Page 2 of 2 | All times are UTC-07:00 |
