| Rear Ends https://slantsix.org/forum/viewtopic.php?t=31902 |
Page 2 of 2 |
| Author: | dusterguy225 [ Tue Oct 28, 2008 2:52 pm ] |
I need to stick with the SBP, Im not loosing my Cragars! Any other options? |
| Author: | 66aCUDA [ Tue Oct 28, 2008 6:51 pm ] |
Do a search thru carparts.com and see what you come up with for a SG 7 1/4 A body rear with 4 inch 5 lug pattern. As for Cragers you can get them in BBP also. And when you convert to Disc you will have BBP all the way around then its into the 15 inch tires etc. Frank |
| Author: | dusterguy225 [ Tue Oct 28, 2008 7:07 pm ] |
Quote: Do a search thru carparts.com and see what you come up with for a SG 7 1/4 A body rear with 4 inch 5 lug pattern. As for Cragers you can get them in BBP also. And when you convert to Disc you will have BBP all the way around then its into the 15 inch tires etc.
Ok, Thanks, but new Cragars are expensive for my taste, especially scince I already have a pair. As for the disc conversion, I am going with the 70-72 A-Body disc setup, for the SBP. Frank |
| Author: | slantzilla [ Tue Oct 28, 2008 11:43 pm ] |
Keep an eye on the for sale section here. There was a SG unit and a set of 3.91 gears for a 7-1/4 on there a couple weeks ago. |
| Page 2 of 2 | All times are UTC-07:00 |
