It is currently Sat Nov 28, 2026 12:53 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Wed Nov 05, 2008 3:37 am
Thanks Thor! Does it matter what year of Aspen/Volare? Excuse me, I'm a Newbie, but who is MiDi?
PostPosted: Wed Nov 05, 2008 8:29 am
Thor....Found MiDi and sent a PM. Thanks again!
PostPosted: Wed Nov 05, 2008 10:21 am
Wouldnt the Aspen/Volare pipe have a space for the catalitic converter and not work with the earlier (74 and older) A bodies? Please let me know I would like a simple swap to upgrade my exaust also.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Wed Nov 05, 2008 11:35 am
Speaking of better flowing exhaust... I rigged up a 2.25" side pipe with a cherry bomb exiting behind the drivers side passenger door (4 door hard top). The tone is a bit harsh for daily driving but when im in 3rd gear going 70mph up a hill it picks up speed like never before.
PostPosted: Wed Nov 05, 2008 12:17 pm
You can still buy brand new a 2.25" manifold pipe for an Aspen/Volare that should fit right under the hood of your '72.
Mmmm...nope! The F-body headpipe configuration is totally different from the A-body headpipe. Remember, the F-body headpipe snakes under the oil pan, across to the passenger side of the car and rearward from there. The A-body headpipe does a couple of bends and zags down and rearward without crossing over to the other side of the car.
But you can cut the top seven-eight inches off an F-body headpipe, bolt it to the exhaust manifold, and have an exhaust shop weld on from there (that is if your shop can't manage to put together a 2¼" headpipe and flange...which if they can't, you might should think about using a different exhaust shop! :shock: )
They are pretty cheap from what I remember. Contact MiDi for more info... he is the one who showed it to me.
From there, use a magnaflow. I've run a 50 series flowmaster with 2.25" and it sounded nice, not loud by any means, however, all flowmasters and knock-offs can produce quite a drone around 60 mph.
Just watch out for MiDi's 64 GT, he's got a helluva fart can stashed under his rear bumper.
~THOR~[/quote]
