It is currently Tue Nov 24, 2026 12:17 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Sun Nov 02, 2008 4:22 pm
played with the carb and it sill did it i think its running lean couse it ran fine when i wired the choke shut
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Sun Nov 02, 2008 6:02 pm
yes that points to a lean condition, your going to have to check fuel pressure with a gauge T in the line and for vacum leaks.
PostPosted: Mon Nov 03, 2008 4:52 am
well i found one open vacume port and just put a hose and a nail for now but the funny thing is when it is just ideling by the shop not driveing it it is fine just when u drive it
PostPosted: Mon Nov 03, 2008 6:49 am
yes when you move the throttle the extra air leans it out, at idle and no load it might just idle a little higher.
PostPosted: Mon Nov 03, 2008 9:59 am
Also, check to make sure that your carb bolts are tight.... I've had that one burn me before... waste all day looking for problems, when the obvious one was that the carb was loose. You may also look into getting a new gasket for it.
Easy check for vacuum leaks.
With the engine running, take some carb cleaner, and spray around the manifold to head gasket surfaces, the Vacuum tree on the manifold, and around the carburetor. Any leaks in these areas will cause the engine rpm to drop, and if it does, then you have found your vacuum leak...or at least one of them.
Is this a california emissions car? If so, and your emissions stuff is still attatched, that may be the source of your problems as well.... :shock:
~THOR~
Users browsing this forum: DuckDuckGo [Bot] and 12 guests
