Tips on exhaust
https://slantsix.org/forum/viewtopic.php?t=32080
Page 2 of 7
Author:  dusterguy225 [ Thu Nov 06, 2008 1:44 pm ]
Remember to run 2 1/4 pipe no larger or smaller.
Frank
Why not 2 1/2 pipes? I was thinking about going 2 1/2 back to the muffler and 2 1/4 dual outs.
Author:  illldeca [ Thu Nov 06, 2008 2:56 pm ]
ya sure a used one and hobart makes some cheap good ones what do you mean by cheap?
Author:  emsvitil [ Thu Nov 06, 2008 3:30 pm ]
Is there any such thing as a cheap MIG??
Joe
Harbor Freight on sale...........
I haven't had any problems with mine.
But I wouldn't recommend the gasless MIGs. Welds are much cleaner (no slag) with at least CO2.
Author:  SlantSixDan [ Thu Nov 06, 2008 4:19 pm ]
Bigger is not necessarily always better. You want to keep the exhaust velocity up at the head of the system; too large a pipe spoils that. Besides, the manifold outlet is 2". You can hone it a little to 2 and a fraction, but 2½" is going to make it basically impossible to seal the headpipe flange to the manifold outlet.
Author:  dusterguy225 [ Thu Nov 06, 2008 8:47 pm ]
So 2 1/4 is absolutly the largest I should go?
Author:  illldeca [ Thu Nov 06, 2008 8:48 pm ]
Joe
slag isnt bad... if u weld right
Author:  Joe Colby [ Fri Nov 07, 2008 4:33 am ]
So Dan, Is 2" the right way to go or 2 1/4"?? It would seem that to keep it simple (the old KISS works for me) would be to go with 2" or is that too constrictive? I don't want to start a raging debate here on size!!
Thanks.
Joe
Author:  SlantSixDan [ Fri Nov 07, 2008 6:20 am ]
There's no reason to use 2" or 2½" instead of 2¼", which is a known-good size from every perspective (function, fit, etc.).
Author:  Joe Colby [ Fri Nov 07, 2008 9:14 am ]
I guess I'm confused about the exhaust outlet being 2" working with 2 1/4" pipe??
Joe
Author:  SlantSixDan [ Fri Nov 07, 2008 12:20 pm ]
It works fine (the factory did it that way starting in '76).
Author:  Joe Colby [ Fri Nov 07, 2008 2:45 pm ]
Dan, I'm sorry, you're going to have to walk me through this. You've got a 2" hole in the exhaust outlet, how do you stuff a 2 1/4" pipe in there??
Pictures might help. Once I get the concept I'm fine, but until then.....
Thanks .
Joe
Author:  emsvitil [ Fri Nov 07, 2008 2:47 pm ]
Thanks .
Joe
You don't.
The exhaust diameter steps up to 2.25" at the exhaust flange that's flush against the exhaust manifold.
Author:  Joe Colby [ Fri Nov 07, 2008 3:53 pm ]
Dan, OK I get it now.
Thanks.
Joe
Author:  Eric W [ Fri Nov 07, 2008 4:10 pm ]
Hey, I'm doing that tomorrow (going from 2" to 2.25")! :mrgreen:
Author:  dusterguy225 [ Fri Nov 07, 2008 7:24 pm ]
Whats the best muffler for a nice deep sound, but its still pretty loud? I was thinking a flowmaster 40 series.
Page 2 of 7 All times are UTC-07:00
