| Any door cars under 2000 lbs.? https://slantsix.org/forum/viewtopic.php?t=32454 |
Page 2 of 4 |
| Author: | Joshie225 [ Fri Nov 28, 2008 10:40 am ] |
My Omni project is quite a ways off as there is a ton of fabrication needed to make that car a reality. In the mid term I'm putting a +.040" 198 in a 1987 RX-7 and calling it the RX-203. I'm hoping for low 14s normally aspirated and high 12s bottle fed. The chassis has a full roll cage and a stripped interior with a Momo race seat and little else. The car has the larger turbo differential with 4.10 gears and a good clutch type limited slip. Hopefully the half-shafts hold up. The trans is ready, the engine needs some oiling mods, the head needs to be ported and then I can assemble the motor. I'm waiting on the motor plate, but have most everything else. So it's put the engine together, trim the motor plate to fit the chassis, fab the trans mount, fab radiator brackets, some plumbing and wiring. Need to mount the shifter and build the driveshaft too. Should be able to make the first race if I stay focused. I expect the car to weigh about 2500 lbs without resorting to cutting sheet metal or expensive stuff like Lexan windows. |
| Author: | wayne erickson [ Fri Nov 28, 2008 11:16 am ] |
Thanks Josh for the updates...Soory I called your project a Arrow...Hopefully CJ and correct it the Mazda 203..Now we need to hear from all the others listed about their "winter projects"..take care and thanks for all your support this year... |
| Author: | ceej [ Fri Nov 28, 2008 12:23 pm ] |
I started a "Projects" Thread that folks can post to. I made the correction to Josh's car. I don't think I'm going to be on schedule for next year, but will be working on it over the winter. CJ |
| Author: | Joshie225 [ Fri Nov 28, 2008 12:54 pm ] |
No worries on the car name. It doesn't mean much until it makes a pass anyhow. No secrets in my house. Not yet at least. |
| Author: | sergio [ Fri Nov 28, 2008 6:30 pm ] |
I know 12's is not a hugh accomplishment Lou ,but i am talking lt. weight with no power adders. I am waiting on some deep thinkers ( dreamers )to develop a closed chamber head with long valves,turbos ,port injection etc. and see what can be done with beloved slants. |
| Author: | Exner Geek [ Sat Nov 29, 2008 8:05 pm ] |
Once and a while I think about building a new car to get down to 2000# with better aero dynamics and weight distirbution than the Valiant. It can be done, Dale Rose's Arrow weighed about 1950 with him in it before he added the supercharger set up. The engine, transmission, and fluids weigh about 700# so a complete rolling chassis would have to weigh less than 1300 minus the wieght of the driver. You can do this but it probably means 4130 tubing and lots of expensive light weight parts and attention to detail. The nice thing about reducing the weight of your car is that it always works and doesn't effect durability. |
| Author: | Challenger [ Sun Nov 30, 2008 1:05 pm ] |
| Post subject: | 81 challenger |
slant six in 81 challenger. weight 2050 lbs without driver. Still for sale Glen. Run in the 11's with a 250 lb hog inside. |
| Author: | Charrlie_S [ Sun Nov 30, 2008 3:18 pm ] |
Quote: I know 12's is not a hugh accomplishment Lou ,but i am talking lt. weight with no power adders.
In my opinion, anyone that can put a N/A slant door slammer in the 12's, has really accomplished something. There are not a lot of them out there.Granted I am a low buck racer, but I haven't got into the 12's even with nitrous, and I am a long way from 12's N/A. |
| Author: | slantzilla [ Sun Nov 30, 2008 3:55 pm ] |
Quote: Quote: I know 12's is not a hugh accomplishment Lou ,but i am talking lt. weight with no power adders.
In my opinion, anyone that can put a N/A slant door slammer in the 12's, has really accomplished something. There are not a lot of them out there.Granted I am a low buck racer, but I haven't got into the 12's even with nitrous, and I am a long way from 12's N/A. I'm gonna guess that even with the motor out of my red car in the Daytona it will still be a 13 something second car. |
| Author: | slantasaurus [ Sun Nov 30, 2008 4:02 pm ] |
| Author: | GTS225 [ Sun Nov 30, 2008 4:23 pm ] |
Quote: No. I have never even seen one in person. If you built oneout of a three wheeled chassis I don't know if you could pass the tech inspection at a race track.
***********************************************************Well, first, most of the imported Isettas were actually four-wheel versions for the U.S. market. The two rear drive wheels were pretty close together, but there was two of them back there. The European cars were the three-wheeled versions, of which a few did make it here in the earlier years. My idea is for a street-legal, four-wheeled car, but I want to run the body backwards on a tube chassis, open engine out front, and a track T nose. Full tub across the (now) rear for a narrowed 8.75 on wishbones and coil-overs, straight axle up front, and a solid-panel roof hatch in place of the soft roof that they had originally. Think along the lines of the vintage Fiat and Bantam gassers of the early-mid 60's. My biggest problem is locating one within my budget, as well as one that's not too complete or in too good of shape. I'm enough of a purist that if it's too good, it should be restored, not hacked up by somebody building a hot rod. Roger[/i] |
| Author: | ceej [ Sun Nov 30, 2008 4:29 pm ] |
Weird. And I mean that in a nice way. An Isetta doing 100 backwards down the track. Yep. Weird. CJ |
| Author: | GTS225 [ Sun Nov 30, 2008 4:39 pm ] |
Quote: Weird.
***********************************************************And I mean that in a nice way. An Isetta doing 100 backwards down the track. Yep. Weird. CJ Yep! Can't say whether it'd break into triple digits, but there'd sure be some speculation around the pits before the first run, especially if it had wing pipes and my Hilborn setup hangin' off of it. Roger |
| Author: | ceej [ Sun Nov 30, 2008 4:48 pm ] |
My Dad's best friend told me a tale once about a ride in one of Dad's Isettas. Dad managed to get it up to 65 on I5 going down hill. This was back around 1962. He said it was the most frightening ride he ever took! That he managed to get a 350cc single with two grown men up to that speed is pretty remarkable. I think Dad referred to that adventure as "Hair Raising." CJ |
| Author: | Dart270 [ Mon Dec 01, 2008 1:02 pm ] |
I thought I might kick off a little banter with that 12's comment. Sergio, you would be in very good company if you run in the 12s - go for it! With luck, I'll have something in the 12's in the next 2-3 years. Lou |
| Page 2 of 4 | All times are UTC-07:00 |
