It is currently Sun Nov 22, 2026 9:16 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Dec 07, 2008 12:08 pm
I'm thinking that you should be able to mount a stock type fuel pump.On the 90 318 there was a block off plate bolted where the pump goes.It's possible MoPar didn't put the excentic piece on the cam gear(it's a off set cup under cam gear bolt) if its there no problem.If not you'd have to remove the whole timing cover/waterpump to install one.If thats the case electric would be the way to go.Good luck 8)
PostPosted: Sun Dec 07, 2008 1:14 pm
If you cannot use the mechanical pump (actually, even if you can), why not stay with the electric pump in the tank, and use a return flow pressure regulator.
Users browsing this forum: Bing [Bot] and 12 guests
