85 Ram Slant 6 to 88 318 V8 Swap
https://slantsix.org/forum/viewtopic.php?t=32622
Page 2 of 2
Author:  6shotvanner [ Sun Dec 07, 2008 12:08 pm ]
I'm thinking that you should be able to mount a stock type fuel pump.On the 90 318 there was a block off plate bolted where the pump goes.It's possible MoPar didn't put the excentic piece on the cam gear(it's a off set cup under cam gear bolt) if its there no problem.If not you'd have to remove the whole timing cover/waterpump to install one.If thats the case electric would be the way to go.Good luck 8)
Author:  Charrlie_S [ Sun Dec 07, 2008 1:14 pm ]
If you cannot use the mechanical pump (actually, even if you can), why not stay with the electric pump in the tank, and use a return flow pressure regulator.
Page 2 of 2 All times are UTC-07:00
