We are shooting for the low sixes maybe high fives with our
https://slantsix.org/forum/viewtopic.php?t=32643
Page 2 of 3
Author:  james jaggers [ Mon Dec 15, 2008 4:46 pm ]
Post subject:  Duster
The duster weighs 2825# with driver. It has a 727 with trans brake 9" converter. It has a 4.30 ultra light ring and pinion and spool. Gun drilled 35 spline moser axles. Aerospace disk brakes on all four corners. The engine is a 225 with a stock cam. It has a 70mm t-4 turbo and a aluminum hand built intake with a 825 demon blow through carb. It also has a fogger nos system and a huge inner cooler. Last but not least it has a hand built 304 stainless turbo header 6 into 1 into a t-4 turbo flange.
The suspension is leafspring cal-trac with double adjustable coil over. The tires are 325-50-15 m/t drag radial so we will have no traction problems. We will start tuning this spring. We also use a digital 7 with boost control. I believe keeping detination out of the engine is going to be the key to making it work.
Author:  Shaker223 [ Mon Dec 15, 2008 4:59 pm ]
Any pics? Probably leaving a lot on the table with that stock cam.
Author:  james jaggers [ Mon Dec 15, 2008 6:32 pm ]
Post subject:  cam
This engine is not my good engine with all the good stuff and the good head. This the engine I am offering up to the Gods of speed. The turbo and the nitrous do not really mind poopy cams and heads. They seem to make up the difference. The engine does have arp head studs and other good fasteners.
Author:  Dart270 [ Mon Dec 15, 2008 8:47 pm ]
God of speed - a noble offering. I want to see this sucker run...
Author:  slantzilla [ Tue Dec 16, 2008 3:27 am ]
With a snail and a hose you may want to put a diaper on the motor so you don't offer up some bodywork to the God of Wall. :shock:
Author:  kafer65 [ Tue Dec 16, 2008 12:08 pm ]
Which ever way you want it to go boom. Rev it to 7500 with 31 Lbs of boost or go EASY on it and rev to 6500 with a 150 shot of nitrous will get you to the minimum high 6 number. It might actually make it all the way down the track with lots of nitrous vs the death rpm. I saw something where you could do up to half of the hp your making in added nitrous--safely. I say go easy on the revs (5000rpm) and dump 350hp shot of juice at it. Now that would be a good daily driver :twisted: I'd need a diaper too if I were driving it.
________
silver surfer reviews
Author:  CARS [ Tue Dec 16, 2008 1:00 pm ]
I like that one 'zilla :lol: :lol:
Author:  slantzilla [ Tue Dec 16, 2008 2:16 pm ]
I've seen a lot of guys crying about having to run diapers on their S/Pro cars, but I have also seen guys save what would have been real bad wrecks because they had one. :shock:
Author:  james jaggers [ Wed Dec 17, 2008 5:58 pm ]
Post subject:  diaper
I have one for the engine. I also have a box of depends for myself although I'll probably need only one.
Author:  slantzilla [ Wed Dec 17, 2008 7:23 pm ]
Post subject:  Re: diaper
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Author:  james jaggers [ Thu Dec 18, 2008 5:59 pm ]
Post subject:  pics
I will post some pics soon!
Author:  madmax/6 [ Thu Dec 18, 2008 6:56 pm ]
Hopefully not of the Depends,mark
Author:  steponmebbbboom [ Thu Dec 18, 2008 7:19 pm ]
BWAHAHAHAHAAAAAAA
Author:  james jaggers [ Wed Dec 31, 2008 5:16 pm ]
Post subject:  Getting closer
Getting closer, sorry I have not posted any pictures lately.
Author:  james jaggers [ Fri Jan 16, 2009 5:48 pm ]
Post subject:  turbo
I am finally posting some pictures.
Page 2 of 3 All times are UTC-07:00
