| Advice for thermoquad on a slant six? https://slantsix.org/forum/viewtopic.php?t=32793 |
Page 2 of 2 |
| Author: | 440_Magnum [ Thu Dec 18, 2008 2:40 pm ] |
Polarizing- yeah I think the TQ was probably the highest point in the evolution of the carburetor. If its working right, it is simply amazing in how it can adapt to anything from a 318 to a 440 without you needing to turn a single screw. Yes, its better if you do tweak the idle mix and the secondary air-door tension, but it really works fine even if you don't. That said, those paint-can sized secondaries are big enough for one TQ to feed two slant-sixes. The air-door never even fully opens on a 318. I have two problems with all the TQs I've seen: first and foremost is the morons who worked on them before me. I've never had one fail from anything other than abuse during a rebuild. Second is the X-section O-rings at the base of the main jet wells which do eventually start to leak, causing the morons from item #1 to even open the carb in the first place. |
| Author: | 440_Magnum [ Thu Dec 18, 2008 2:45 pm ] |
Quote: Quadrajets came on cop-spec 318s (possibly also trucks?) through at least 1984. All Lean-Burn equipped!
Definitely also on trucks (360s more often than 318s in that app). Chrysler switched to the Q-jet after the TQ was no longer available, so your "through 1984" doesn't quite compute- it would have been through 1989 and STARTING in 85 or thereabout. It was all TQ before that.
| Author: | SlantSixDan [ Thu Dec 18, 2008 2:52 pm ] |
Read what I meant, not what I typed! |
| Author: | Wesola78 [ Tue Dec 23, 2008 8:22 am ] |
Well, I have one Carter Thermoquad in my garage, late sixties or early seventies, I'm not sure. When I stripped the Diplomat cop car a few years ago (which I bought non-running for $25 dollars!), it had a thermoquad on top of it's 318. I used this carb as a core for the Carter bbd I bought from O'Reilly's. I agree on these carbs being "polarizing". |
| Author: | 440_Magnum [ Tue Dec 23, 2008 8:30 am ] |
Quote: Read what I meant, not what I typed!
The scary thing is that I've known you long enough that I can almost do that... |
| Page 2 of 2 | All times are UTC-07:00 |
