| i need info on some cheap smog legal performance mods https://slantsix.org/forum/viewtopic.php?t=32822 |
Page 2 of 2 |
| Author: | LLangarica [ Thu Dec 18, 2008 11:28 am ] |
alright thanks. would you know where i have to go to get it certified once i add the super six set up? do i have to pay anything? |
| Author: | emsvitil [ Thu Dec 18, 2008 5:27 pm ] |
If the 2bbl carb was optional, you should be able to make it a 2bbl. I'd make it look as stock as possible. and not bother trying to certify it. They usually don't take off the air cleaner, so they might not notice 2bbls if all the hoses and connections are there........... |
| Author: | 77PartyWagon [ Thu Dec 18, 2008 6:10 pm ] |
If you could make it look as stock as possible, you might get away with it and not have to have it certified. They will check everything based off of the smog sticker that is under the hood of the car that tells where all the hoses are supposed to go. You have to take it to a referee station to have it certified. And this is CA, of course it will cost something. How much I don't know, I never have yet made it that far. I gave up with the first engine swap I was contemplating, and the swap I was contemplating with the Aspen I am not gonna do now... going to keep the /6 in it for awhile (i like being a little different) |
| Author: | LLangarica [ Thu Dec 18, 2008 6:24 pm ] |
Quote: If you could make it look as stock as possible, you might get away with it and not have to have it certified. They will check everything based off of the smog sticker that is under the hood of the car that tells where all the hoses are supposed to go.
i think i will go and look for a set up in the junk yard and try it out. i dont have to smog it for a nother year and a half so i will just play around with that until then. thanks.
| Author: | CARS [ Thu Dec 18, 2008 6:40 pm ] |
Jeez, I sure am glad I don't have to go through that crap. Have you tried peeling off an inspection sticker from a passed vehicle? If you were pulled over do they really check the numbers??? I can't believe that the cops have nothing else to do than check smog stickers. Or do you have to prove a passed test to get tabs or insurance? (go ahead and rip on me for this suggestion. Just remember the stones you throw when you go a mile per over the speed limit tomorrow |
| Author: | 63d100sixer [ Thu Dec 18, 2008 6:58 pm ] |
Quote: Jeez, I sure am glad I don't have to go through that crap.
Have you tried peeling off an inspection sticker from a passed vehicle? If you were pulled over do they really check the numbers??? I can't believe that the cops have nothing else to do than check smog stickers. Or do you have to prove a passed test to get tabs or insurance? (go ahead and rip on me for this suggestion. Just remember the stones you throw when you go a mile per over the speed limit tomorrow In california, when you get "smogged" they send an electronic certificate to the DMV, so you can get your tags. You also get a paper copy. We dont get inspection stickers or anything, just tags, and yes, they check the numbers sometimes. When the CHP, for instance, runs your registration, they will know the tags are fake, if you have fake tags |
| Author: | LLangarica [ Thu Dec 18, 2008 7:01 pm ] |
Quote: Have you tried peeling off an inspection sticker from a passed vehicle? If you were pulled over do they really check the numbers??? I can't believe that the cops have nothing else to do than check smog stickers.
you have to pass a smog test to get your car registered. with out a registration you dont get the license plate tags and its basically fresh meat for any police officer.
Or do you have to prove a passed test to get tabs or insurance? |
| Author: | steponmebbbboom [ Thu Dec 18, 2008 7:24 pm ] |
Quote: Quote: Have you tried peeling off an inspection sticker from a passed vehicle? If you were pulled over do they really check the numbers??? I can't believe that the cops have nothing else to do than check smog stickers.
you have to pass a smog test to get your car registered. with out a registration you dont get the license plate tags and its basically fresh meat for any police officer.Or do you have to prove a passed test to get tabs or insurance? if a cop tries to pull you over, just Gun it they won't care |
| Author: | 63d100sixer [ Thu Dec 18, 2008 7:27 pm ] |
Quote: Quote: Quote: Have you tried peeling off an inspection sticker from a passed vehicle? If you were pulled over do they really check the numbers??? I can't believe that the cops have nothing else to do than check smog stickers.
you have to pass a smog test to get your car registered. with out a registration you dont get the license plate tags and its basically fresh meat for any police officer.Or do you have to prove a passed test to get tabs or insurance? if a cop tries to pull you over, just Gun it they won't care then its a 30 mandatory hold in an impound lot, suspended license for 18 months, and a year on probation ask me how I know |
| Author: | CARS [ Thu Dec 18, 2008 7:49 pm ] |
ask me how I know
Nuff said. I wasn't saying to do it, just wondering how to help get around the situation.Move to MN? Na, it's 2 degrees right now. |
| Author: | LLangarica [ Mon Dec 29, 2008 1:12 pm ] |
does anyone know of a good C.A.R.B certified cam shaft? |
| Author: | coconuteater64 [ Mon Dec 29, 2008 1:42 pm ] |
I can assure you they will not check the cam! If it lopes maybe, but the good street cams for a slant won't make them take much notice. As for the smog, they cram a hose up your tail pipe Oh yeah, they failed my wife's car because of the gas cap. |
| Page 2 of 2 | All times are UTC-07:00 |
