Yesterday's adventures in Dart repair
https://slantsix.org/forum/viewtopic.php?t=33006
Page 2 of 2
Author:  SlantSixDan [ Sat Jan 03, 2009 6:39 pm ]
Does the door still rise all the way to the heat-on position like it did before? What size vacuum tube did you use?
Author:  Eric W [ Sat Jan 03, 2009 7:19 pm ]
Yes, it still raises up. I actually used some washer fluid hose I had. Its a small ID and OD so it dosn't interfier with the operation of the door. Its the same size as some vacuum hose you may find on, say, a Holley 1945. Don't know how long it will last though. I'm sure the heat will harden it up pretty fast.
Author:  SlantSixDan [ Sat Jan 03, 2009 7:50 pm ]
I'll give that a try! Looks like the leading edge of the door is sort of wrapped/curled under, so it could be difficult to get the hose onto the door itself...
Author:  Eric W [ Sat Jan 03, 2009 8:04 pm ]
Yeah, on mine it is slightly raised on the trailing edge (facing the air cleaner). It almost looks like it was put there to draw a slight amount of hot air into the air cleaner. Guess the engineers had a reason for this...Did that guy from Fram ever get back to you?
Author:  wjajr [ Sun Jan 04, 2009 8:12 am ]
Dan:
I find the rattle coming from the leading edge of the door hitting the floor of the snorkel,
I don't have, or have seen this particular rigging, but understand its basic architecture. How about a small bead of silicone to form a stop for the door?
Page 2 of 2 All times are UTC-07:00
