Fender Prep
https://slantsix.org/forum/viewtopic.php?t=33034
Page 2 of 2
Author:  ESP47 [ Wed Dec 31, 2008 7:15 pm ]
Slightly off topic, but would this thing work to remove paint from metal interior pieces such as sail panels?
http://www.harborfreight.com/cpi/ctaf/d ... mber=94015
Yes, but... Why not use sandpaper? With that wheel you are going to have to prime, sand, prime, sand and paint. That type of wheel makes quick work of scale and rust but interior paint should be easy to get off.
180 grit paper should make short work of an interior panel.
Ok thanks, I'll just use the wheel on the inside of the panel where there is surface rust and then sand the outside.
Page 2 of 2 All times are UTC-07:00
