Hub/drum replace or repair?
https://slantsix.org/forum/viewtopic.php?t=33174
Page 2 of 4
Author:  MiDi [ Tue Jan 06, 2009 7:51 pm ]
i need to go up to wildcat and grab a shorter throttle cable real soon. so shoot me a p/m swingergrrl73 about what you need i'll grab one up @ wildcat and dump it off @ the shop for ya. i have a pile of crap there i need to bring home anyways.
MiDi
Author:  Joshie225 [ Tue Jan 06, 2009 7:54 pm ]
the guy did mine for $10. thats for both.
That's exceptionally inexpensive.
Author:  steponmebbbboom [ Tue Jan 06, 2009 8:03 pm ]
something about shear values and temperature
that information is only available online to registered accounts with a corporate password but can probably be had by calling tech support in miami, toll Free: 1 (800) 238-3280
Author:  SwingerGrrl73 [ Wed Jan 07, 2009 6:08 pm ]
Eric W-times and monies tight. I have to do what I can a little at a time. Sigh. I will talk to Noel about doing the rest of what needs to be done so that my car stays on the road with me behind the wheel. :wink:
I printed this thread so I can read it all at home. I HATE not having interweb at home!!!!
Author:  SwingerGrrl73 [ Thu Jan 08, 2009 8:37 am ]
Still no blinkers MiDi.
I have to prioritize my car stuff. And I am bad at that.
1. 2 front 10' drums (do both right?)
2. wheel bearings x 2
3. pitman arm/bushings
4. ball joints upper/lower
5. blinker switch
Author:  Joshie225 [ Thu Jan 08, 2009 10:41 am ]
Just fix the drum with the bad bearing. If you get a good used drum and hub assembly is should have bearings with it and you should be able to just repack those bearings and replace the seal.
Author:  SwingerGrrl73 [ Thu Jan 08, 2009 1:21 pm ]
Good point Joshie.
Author:  SwingerGrrl73 [ Thu Jan 15, 2009 4:37 pm ]
I'm in dire straights here people.
I barely made it to work today. I doubt I will make it home if I even try in my car.
I can't find a brake drum for my car anywhere. Oh, except Tampa BLEEPING Florida.
WA slanters....help me with a used one! Does anyone have one, or does anyone have a clue where I can get a used one here?? It needs to happen like 2 weeks ago. (Yes, Eric I know!!)
Author:  Reed [ Thu Jan 15, 2009 4:51 pm ]
The Autozone by my house has a 9 inch front drum for $150. :shock:
Napa carries a new 9 inch front drum for $105. :?
Dang, that's pricey! Somebody out there has to have a 9 inch front drum for you.
Author:  SwingerGrrl73 [ Thu Jan 15, 2009 4:55 pm ]
mines are 10....
Author:  Joshie225 [ Thu Jan 15, 2009 5:13 pm ]
I really wish you'd come to the forum about 6 months earlier. I tossed two perfectly good 10" drums. Actually, they might not have worked for you. What year is your car?
Author:  Reed [ Thu Jan 15, 2009 5:13 pm ]
Oh, well those are cheaper, about 80-90 bucks per drum. Napa and Autozone also carry ten inch drums.
Author:  Joshie225 [ Thu Jan 15, 2009 5:15 pm ]
True, but she needs the drum for it's hub and new drums don't come with hubs.
If her car is '73 or newer there is a drum in Portland for $25 at Burnside Used Truck Parts 1-866-877-8969. They used to do more than just trucks.
Author:  SwingerGrrl73 [ Thu Jan 15, 2009 6:32 pm ]
Sigh.
I've called Napa. The only one they can get is the one in Tampa. Schucks can have one in a week. I need it now. Leaving her at work over night. Riding the bus to work tomorrow. That's gonna suck. Have to leave 3 hours before I need to be at work. Lame-o.
Author:  Aggressive Ted [ Thu Jan 15, 2009 6:39 pm ]
Did you ask Les Schwab how much they want for them? I have gotten new ones from them for my 69, etc..
Page 2 of 4 All times are UTC-07:00
