proportioning valve question
https://slantsix.org/forum/viewtopic.php?t=33916
Page 2 of 2
Author:  sandy in BC [ Sat Feb 28, 2009 4:03 pm ]
After doing some reading about 4x4 truck rear disc conversions I decided to try leaving the stock 75 valve in the Valaint when I went to 4 wheel disc. It stops very nicely without any extra prop valve.
If the brake proportioning is right for drums ....its likely right for correct sized discs. I used Explorer 8.8 rear and discs.
Id try the stock setup before messing with anything extra.
Author:  Zipper [ Sat Feb 28, 2009 8:56 pm ]
To swing the thread back, as I'm talking with the previous owner, Delphine (the Dart) always pulled right. Also the master Break cylinder is from a 75. Is it common to change the Break cylinder when doing a disk conversion?
Author:  slantfin [ Sun Mar 01, 2009 10:23 am ]
I agree with dakight and emsvitil, your problem is probably a caliper or hose. You can convert an all-drum master cylinder by removing the residual pressure valve for the front brakes, but it wouldn't be as good as a purpose-built one, where there is a lower pressure valve for the front. That way the calipers are ready to go, but not dragging.
Page 2 of 2 All times are UTC-07:00
