| '72 318 - undo emissions detuning? https://slantsix.org/forum/viewtopic.php?t=34368 |
Page 2 of 2 |
| Author: | '72Jim [ Thu Mar 19, 2009 7:55 pm ] |
deleted |
| Author: | kesteb [ Thu Mar 19, 2009 8:25 pm ] |
In Washington State, a vehicle built in 1972 doesn't need to go thru emission testings. If you lived 30 miles outside of the 1-5 corridor in the Pudget Sound area, you also wouldn't need to do testing. |
| Author: | SlantSixDan [ Thu Mar 19, 2009 8:29 pm ] |
72Jim, why are you working so hard to override this board's very effective text-quote system? Adding your own quotation marks, disabling BBCode...why? All it's doing is making your posts a damnuisance to read. Please knock it off. |
| Author: | Charrlie_S [ Fri Mar 20, 2009 5:28 am ] |
Why are we haveing a flame fest in this thread? It doesn't really belong here, in the first place. This is about a 318 V-8. We have been tolerant about questions on other engines/cars, from members, but that is usually in the social corner. |
| Author: | 72Duster08 [ Sat Mar 21, 2009 6:21 pm ] |
Well, I took the car out for the first real run today, it wasnt registered until yesturday, so I didnt have a chance to actually drive it until now. But Wow that 318 had more power than I expected, Must be the excessive amount of torque. had a lot of people compliment the car at stop lights. haha. and I also relized how bad the gas milage was, I burned 1/4 a tank of gas in about 50 minutes of city driving. (some play driving) So I definately wont be switching to the 4bbl, will more than likely just plug in the holes in the intake manifold. If anything, I would just upgrade to a better 2bbl, add headers and add a HEI ignition. Eventually maybe a 360 cam. So again, thanks for everyones help. |
| Author: | Reed [ Sat Mar 21, 2009 6:30 pm ] |
If it is in good shape and tuned correctly, the Carter BBD is actually a pretty decent carb. If you want a bit better gas mileage, maybe try a Holley 2280. You can pick up either on eBay fairly cheaply. Anyway, good luck with it! |
| Page 2 of 2 | All times are UTC-07:00 |
