| Community head flow testing? https://slantsix.org/forum/viewtopic.php?t=34835 |
Page 2 of 2 |
| Author: | Joshie225 [ Tue Jul 28, 2009 9:37 pm ] |
When I originally posted about this I had forgotten about all the work James Jaggers had done. In the mean time I hit water when attempting to offset my intake ports. I'll likely fix my head, but will probably forgo the testing. |
| Author: | 66aCUDA [ Wed Jul 29, 2009 6:50 am ] |
Quote: When I originally posted about this I had forgotten about all the work James Jaggers had done. In the mean time I hit water when attempting to offset my intake ports. I'll likely fix my head, but will probably forgo the testing.
JoshIs this work posted somewhere??? Can we get a copy? Thanks, Frank |
| Author: | Rug_Trucker [ Wed Jul 29, 2009 7:27 am ] |
Who has used the MP porting templates? I enjoy porting and polishing. Anyone think unshrouding stock valves will help economy? |
| Author: | Charrlie_S [ Wed Jul 29, 2009 8:22 pm ] |
Quote: Who has used the MP porting templates?
I have never seen any for the slant six. Can you point me to them?
| Author: | Rug_Trucker [ Wed Jul 29, 2009 9:42 pm ] |
They are in the MP book for the 6's page #279 |
| Author: | Charrlie_S [ Thu Jul 30, 2009 4:27 am ] |
Quote: They are in the MP book for the 6's page #279
Is this the MP parts book, or the racing manual?
| Author: | Rug_Trucker [ Thu Jul 30, 2009 5:38 am ] |
racing manual |
| Author: | Charrlie_S [ Thu Jul 30, 2009 8:10 am ] |
Quote: racing manual
I have 4 racing manuals (different years), looked in all of them and still can't find "templates", There are sketckes of the port, but no actual templates. Mopar used to sell a plastic sheet with templates printed on it, for the V-8"s. You would cut the template of of the sheet, and use it as a guage, in the post to guid your grinding. I have never seen one for the slant.
| Author: | mopardemon71 [ Thu Jul 30, 2009 8:26 am ] |
Josh, If you can wait awhile you could run you test of the more built heads with and w/o the hurricane intake as well. Intakes can hamper intake flow as well. I will see if I can find my flow sheet for my head. I am running 1.72I/1.50E chevy's. I dont know for sure but altitude is 2800 feet or so. I got 195 cfm at .650 ant 200 with no valve. Josh what is your elivation? I'll see if I can free some cash for you as well. |
| Author: | slantsixlancer [ Thu Jul 30, 2009 8:43 am ] |
did I read this right..the testing is off for now?? If not I'll help what I can.....Recipes for a /6 build seem hard to come by this would help alot...count me in Quote: If you can wait awhile you could run you test of the more built heads with and w/o the hurricane intake as well
Ha Ha...this could be alot of fun |
| Author: | Rug_Trucker [ Thu Jul 30, 2009 12:21 pm ] |
Quote: Quote: racing manual
I have 4 racing manuals (different years), looked in all of them and still can't find "templates", There are sketckes of the port, but no actual templates. Mopar used to sell a plastic sheet with templates printed on it, for the V-8"s. You would cut the template of of the sheet, and use it as a guage, in the post to guid your grinding. I have never seen one for the slant. |
| Author: | akbmotorsports [ Thu Jul 30, 2009 1:00 pm ] |
| Post subject: | re; |
i wonder if anyone has tried checking flow of head with intake attached and ported to obtain same flow through all 6 runners to even out flow between runners with intake manifold attached. have also heard of some guys welding a piece of 1/4 inch square aluminum in the intake around the 3 and 4 cylinder runner area to help equalize flow. |
| Author: | Rug_Trucker [ Thu Jul 30, 2009 4:21 pm ] |
| Post subject: | Re: re; |
Quote: i wonder if anyone has tried checking flow of head with intake attached and ported to obtain same flow through all 6 runners to even out flow between runners with intake manifold attached. have also heard of some guys welding a piece of 1/4 inch square aluminum in the intake around the 3 and 4 cylinder runner area to help equalize flow.
I think there is a diagram of that in the archives here.
| Author: | Polara1974 [ Thu Jul 30, 2009 7:11 pm ] |
[quote="Rug_Trucker"]They are in the MP book for the 6's page #279[/quote] Rug I have the MP 6cil. book and I can't find anywere in the text next to the ports sketch that states they are "Performace Temples" it only says that they are a "typical Intake and Exhaust port layout" and (maybe I'm wrong) but I allways have thought that those drawins were of stock ports and not performance ports templates. As I said, maybe I'm wrong... I don't have the book here to double check, but this is what I remenber. Martin |
| Author: | Rug_Trucker [ Thu Jul 30, 2009 8:16 pm ] |
I've never cut them out and checked them in the ports. Never crosses my mind when I'm grinding on a head |
| Page 2 of 2 | All times are UTC-07:00 |
