A body 8 1/4 with 2.45 gears and 11 inch brakes?
https://slantsix.org/forum/viewtopic.php?t=35382
Page 2 of 2
Author:  bigslant6fan [ Tue May 19, 2009 8:07 pm ]
Post subject:  11?
Yes I seen many v-8 A-body 81/4 rears with 11x2" brakes.I,d change the complete set-up to either 10x2 1/2 or 11x2 1/2,because the 11x2s are getting hard to find parts for.
Author:  Reed [ Tue May 19, 2009 8:17 pm ]
Thanks! The 7 1/4 under the car now I *think* has 10 inch drums that felt good on the very short test drive. Maybe i will just swap all of the hardware over.
Author:  Reed [ Tue May 19, 2009 8:46 pm ]
Bolt pattern! D'OH! :roll:
Author:  Joshie225 [ Tue May 19, 2009 8:52 pm ]
Don't worry, you can get 10" drum stuff from an F/M/J, 1/2 ton pickup, van, etc. I have most everything you need if you ever make it down here. Drums, shoes, backing plates, hardware. Yours for the asking.
Author:  kesteb [ Fri May 22, 2009 6:47 am ]
I am running the 2.45 gears in my '65 with a 4 speed. No problems with it at all. I can cruise around town in 4th at 1000 rpms and smoothly accelerate away, 2000 is 60 mph and 3000 is 90mph.
I do have problem taking off on steep hills. A little more clutch slippage then I would like. I wouldn't recommend one with an automatic thou.
Author:  Reed [ Fri May 22, 2009 7:31 am ]
Thanks. We got the rear axle and will make a junkyard run to try and find some 2.94 or 3.2 rear gears. Now to figure out a way to get the pinion nut off the yoke in the junkyard...
Page 2 of 2 All times are UTC-07:00
