It is currently Sun Nov 15, 2026 9:45 pm
PostPosted: Tue Dec 01, 2009 4:00 am
I think you can get away without swapping the spring mounts.
PostPosted: Wed Dec 02, 2009 6:48 am
If I plan on sticking to the 8.25 that is currently installed, how much HP/Torque should it be able to withstand? This will help me decide my options for the motor.
Thanks all
*Rogue
PostPosted: Wed Dec 02, 2009 6:58 am
8 1/4s are pretty good. Unless you go drag racing with a manual trans and slicks I think you're unlikely to find the limits with a slant.
PostPosted: Sun Dec 13, 2009 7:04 am
One other thing I like about the 8 3/4, that is their taper-roller type axle bearings with end play adjustment... not a ball bearing.
(I will never unstand why people would want to use those "Green" bearings on an 8 3/4) :?
Uh Huh... let me use the search function... was it 25000 miles on Green bearings on your Cuda, mostly being towed ;) I remember!
I installed an 8 3/4 on my 74 Duster - here's the thread
Don't recommend cannabalizing an E body these days though...
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
