| Hello Newbe to /6 land https://slantsix.org/forum/viewtopic.php?t=36730 |
Page 2 of 2 |
| Author: | Aggressive Ted [ Sat Aug 15, 2009 10:31 pm ] |
Diego Ted, Sorry I didn't see your post earlier. If you clicked on the red link below my name and took a look at the pictures, that's what I did to solve the problem. Two 1/2" thick gaskets does the trick. I installed longer studs to run them. I have been running that set up for about two years now. No problem with the idle ever or on restarts even on 100 degree days. I run the R7585 1920 Holley Economaster. EconoMaster 1920 Holley R7585 modifications: This set up really wakes up the engine! Reference: .078 = 5/64th Idle mixture hole .080 Idle air bleed #65 drill, .035 Squirter hole #65 drill, .035 Idle @ 4 turns with #61-2 to #64 jet The pump shot is very strong, enough to break the rear loose with a 2.76 posi. For good mileage: 2009 changed back to nearly plugged idle air inlet by peening hole with round tip on scribe. The hole is a very small idle bleed inlet @ .005. with a #57 jet and idle mixture set @ 1 7/8 turns. Glad you figured it out and that it's working for you! |
| Author: | 1980volare [ Tue Aug 18, 2009 10:28 am ] |
heres my heat deflector i made for the bbd super six setup,with a 4 dollar piece of scrap aluminim,a hole saw and cut off wheel, and it works great. ![]() ![]() ![]() got more pics if anyone wants em. |
| Author: | Aggressive Ted [ Tue Aug 18, 2009 10:38 am ] |
1980volare, Very cool! I bet your carb doesn't heat soak now! It sure made a big difference on mine. |
| Author: | Diego Ted [ Tue Aug 18, 2009 7:56 pm ] |
Hey I just found page 2!! Thanks Ag Ted! I am looking forward to trying the carb mods@@ Diego |
| Page 2 of 2 | All times are UTC-07:00 |
