| The World's Lightest Slant Six? https://slantsix.org/forum/viewtopic.php?t=36834 |
Page 2 of 3 |
| Author: | GTS225 [ Sun Aug 23, 2009 4:18 pm ] |
I think I'll WAG it at 305-315, being as Doug doctored that pic and I couldn't read the scale, even blowing it up 300% I gotta say that that engine sure looks "thin". I can't help but think what it might do at Bonneville if somebody shoehorned it into a belly-tank/aero car. Roger |
| Author: | Doctor Dodge [ Sun Aug 23, 2009 8:42 pm ] |
Quote: That is a beautiful looking long block, that ugly water neck must drive you crazy. Just a guess...386#
Good eye...I put that "spare" t-cover on top of the engine , right at weigh-in, we wanted to count it. (like it makes any difference The cover we will use is the one on the car, it is tapped and has a fitting for a temp gauge sender. The touble is... that cover also looks like crap! Time to get out the wire brush and spray paint... DD
| Author: | 66aCUDA [ Mon Aug 24, 2009 4:56 am ] |
301 1/2 sounds about right. Frank |
| Author: | james longhurst [ Mon Aug 24, 2009 9:37 am ] |
Best guess 37 henweighs. -James |
| Author: | Doc [ Mon Aug 24, 2009 9:56 am ] |
Quote: On average, a well cared for laying hen of common stock, should weigh-in between 4 and 6 pounds, live weight.
So... are you in with 148 or 222 pounds? Or do you have some "giant size" hens? DD |
| Author: | Wizard [ Mon Aug 24, 2009 10:42 am ] |
Okay, I'll slide in weight around 275lb. Cheers, Wizard |
| Author: | james longhurst [ Mon Aug 24, 2009 2:23 pm ] |
Doug, I like my hens a little on the thick side! -James |
| Author: | Dart270 [ Mon Aug 24, 2009 6:34 pm ] |
I'm getting hungry for... Lou |
| Author: | 62 alum [ Mon Aug 24, 2009 6:40 pm ] |
Nice----316 |
| Author: | bigviking0001 [ Tue Aug 25, 2009 6:36 am ] |
335.......that's allot of weight off.....the big question I have is how much rotating weight was removed?......have been on the edge of my seat....Thanks Doc |
| Author: | Dart270 [ Tue Aug 25, 2009 8:08 am ] |
Cast crank is 16-19 lbs lighter than stock 225 forged crank. Rods and pistons probably about 2-4 lbs savings over stock stuff. Lou |
| Author: | Doc [ Tue Aug 25, 2009 9:00 am ] |
A total of 22 3/4 lbs of rotating weight came-out when compared with a forged crank, 225 with factory rods & pistons.. The light cast crank accounted for 20 lbs of that, it weighs-in at 56 lbs. DD
| Author: | Doc [ Tue Aug 25, 2009 2:02 pm ] |
Last chance to place your bet... I post Buster's weight tomorrow. DD |
| Author: | Doc [ Wed Aug 26, 2009 1:43 pm ] |
| Post subject: | And the answer is.... |
Buster weighs 272.5 lbs. The "lotto" was close but Wizard is the winner, guessing 275... followed by lowbudget with a 269 pound guess. I found that my scale is rated for 250 lbs but simply hits zero again at 250 pounds... and keeps on going. (Kinda like an old speedo where the numbers stop at 110 but the needle keeps going around and back to zero) As a calibration check, I weighed myself at 226 lbs and then weighed a 8 3/4 case seperatly, it was 33 lbs. Pick-up the case and got onto the scale, it read 9 pounds. (250 + 9 = 259 lbs) Here is a photo of the scale reading. (250 = 22.5 = 272.5) DD
| Author: | emsvitil [ Wed Aug 26, 2009 2:19 pm ] |
And how much would the iron version be? |
| Page 2 of 3 | All times are UTC-07:00 |
