missing second gear?
https://slantsix.org/forum/viewtopic.php?t=37252
Page 2 of 2
Author:  onemoparman [ Fri Oct 02, 2009 5:20 pm ]
it actually looks good and smooth the piece which goes on the end of the kickdown adjuster was cocked side ways adjust against the case if you will. ...... also found out it has converter lockup so its a no go on swping the valve body.... okay next question the low reverse band has about 1/4 to 3/8 play when I rock the adjuster seems excessive the manual gives a procedure but says nothing about the play. thanks in advance
Author:  slantzilla [ Fri Oct 02, 2009 6:17 pm ]
Both bands will have play in them when at rest.
Author:  onemoparman [ Fri Oct 02, 2009 6:19 pm ]
okay cool thanks again the kickdown band defintly explains no second gear if you look at what applied when in the charts in the manaul well back together it goes
Author:  onemoparman [ Sat Oct 03, 2009 3:35 pm ]
got the truck back together and took it for a spin shifts a little early have to adjust the kick down but I got 1 2 and3! thanks for all your help!
Page 2 of 2 All times are UTC-07:00
