It is currently Thu Jun 04, 2026 10:02 pm
 Post subject: FYI - www.weldingweb.com
PostPosted: Sun Dec 13, 2009 9:07 am
Is to welders as slantsix.org is to our engines. Make sure you do searches by model # and other key words, topics like this have been covered there many times.
PostPosted: Sun Dec 13, 2009 10:18 am
Pierre-roger that will definitly check that site out
stonethk-Tig welder for which ?
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Mon Dec 14, 2009 9:32 am
I have the Weld Pak 100. It works well within the limits of its capabilities, but I'd get a more powerful machine if I had it to do over so I could weld heavier stuff. +10 on converting to gas. Also, get a auto-darkening helmet: SO much easier to see what you're doing.
obliquely-inclined state of mind
PostPosted: Wed Dec 16, 2009 6:53 am
but what can you wled, ie stainless, mild, aluminium, cast iron etc all of the above ?
-Mike
Mike
I do mostly sheet metal and mild steel with a Mig. As stated before a Tig is the preferred method for welding alloys and non ferrous metals.
Note I have use my Clarke for welding stainless and Alum with 100% Argon and the proper wire, but it is MUCH cheaper and easyer to use Tig for this.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
