| yet another "is this welder any good Q ?" https://slantsix.org/forum/viewtopic.php?t=37258 |
Page 2 of 2 |
| Author: | Pierre [ Sun Dec 13, 2009 9:07 am ] |
| Post subject: | FYI - www.weldingweb.com |
Is to welders as slantsix.org is to our engines. Make sure you do searches by model # and other key words, topics like this have been covered there many times. |
| Author: | Volare4life [ Sun Dec 13, 2009 10:18 am ] |
Pierre-roger that will definitly check that site out stonethk-Tig welder for which ? -Mike |
| Author: | Red [ Mon Dec 14, 2009 9:32 am ] |
I have the Weld Pak 100. It works well within the limits of its capabilities, but I'd get a more powerful machine if I had it to do over so I could weld heavier stuff. +10 on converting to gas. Also, get a auto-darkening helmet: SO much easier to see what you're doing. |
| Author: | 66aCUDA [ Wed Dec 16, 2009 6:53 am ] |
Quote: but what can you wled, ie stainless, mild, aluminium, cast iron etc all of the above ?
Mike-Mike I do mostly sheet metal and mild steel with a Mig. As stated before a Tig is the preferred method for welding alloys and non ferrous metals. Note I have use my Clarke for welding stainless and Alum with 100% Argon and the proper wire, but it is MUCH cheaper and easyer to use Tig for this. Frank |
| Page 2 of 2 | All times are UTC-07:00 |
