| Vintage looking intake that doesn't suck? https://slantsix.org/forum/viewtopic.php?t=37510 |
Page 2 of 2 |
| Author: | Karasik87 [ Thu Oct 15, 2009 6:47 pm ] |
sand blast a new intake and leave it outside for a bit. that'll get ya some nice surface rust |
| Author: | 66aCUDA [ Fri Oct 16, 2009 6:07 am ] |
Quote: sand blast a new intake and leave it outside for a bit. that'll get ya some nice surface rust
Hum Aluminum rusting, Must be the cheap China kind!!!! Frank |
| Author: | mopardemon71 [ Fri Oct 16, 2009 10:26 am ] |
You could run a crusty iron 2bbl untill you figure it out. |
| Author: | robertob [ Fri Oct 16, 2009 12:52 pm ] |
Think I found an SU manifold. Now to find three HS6 SUs. |
| Author: | robertob [ Fri Nov 20, 2009 2:33 pm ] |
So there you have it. I think I'll use three Datsun Hitachi SUs because they flow 210CFM each and are fairly inexpensive. Should be pretty good for a hot street slant.
| Author: | Reed [ Fri Nov 20, 2009 2:41 pm ] |
I think you mean: ![]() That's pretty cool! Never heard of that manifold before. Where did you find it? |
| Author: | emsvitil [ Fri Nov 20, 2009 3:35 pm ] |
Do you use a lawnmower carb for the little hole on top? |
| Author: | robertob [ Fri Nov 20, 2009 4:00 pm ] |
Secret stash It's australian actually. Probably not the best design for ultimate performance but should work fine on my stock-rod motor. |
| Author: | Reed [ Fri Nov 20, 2009 4:05 pm ] |
Pretty cool. Although, actually, technically, ALL intakes suck (or at least channel the motor's suckiness). |
| Author: | MichaelS [ Sat Nov 21, 2009 7:05 am ] |
Can you fit a triple carb setup on a left hand drive slant? I thought the brake cylinder would be in the way? |
| Author: | robertob [ Sat Nov 21, 2009 8:44 am ] |
Quote: Can you fit a triple carb setup on a left hand drive slant? I thought the brake cylinder would be in the way?
Maybe with power brakes but seems like plenty of space in my car. It doesn't stick out that far actually.
| Author: | DusterIdiot [ Sat Nov 21, 2009 11:31 am ] |
| Post subject: | Yep... |
Quote: Maybe with power brakes but seems like plenty of space in my car. It doesn't stick out that far actually.
That would be correct, the shorty rams with small carbs should fit nicely with manual brakes....Looks like a fun choice to me. -D.Idiot |
| Author: | MichaelS [ Mon Nov 23, 2009 5:53 am ] |
Good to know, please post a picture when installed on the slant. Thanks |
| Page 2 of 2 | All times are UTC-07:00 |
