| Poor Gas Milage https://slantsix.org/forum/viewtopic.php?t=37660 |
Page 2 of 2 |
| Author: | dusterguy225 [ Sat Oct 31, 2009 10:05 am ] |
No, it never even crossed my mind, I will do that this afternoon. The last time I changed the plugs, they were all a good brown color so its probably firing on all 6 |
| Author: | dusterguy225 [ Sun Nov 01, 2009 4:43 pm ] |
I got around to pulling the plugs and checking the gaps and every thing, and noticed that #5 plug was coated in gas, and looked like it had never been used. #6 and #4 were perfect. Started the engine, pulled the #5 wire and it started running rough, ok... so I pulled #6 and there was no change in idle, RPM, no notice in power loss while hitting the gas. I checked if it was getting spark (my hand went numb Oh I forgot to add, I reduced the Idle to 750, and it droped to 600-650 in gear at first, then dropped down to 500 (650 in park/neutral) after some driving. So I adjusted the idle in gear to 650, it has now dropped back down to 550 |
| Author: | Reed [ Sun Nov 01, 2009 5:11 pm ] |
Compression check. Maybe a blown head gasket between #s 5 and 6? |
| Author: | dusterguy225 [ Wed Nov 04, 2009 2:11 pm ] |
I think I might have found the solution to my poor mpg. While I was adjusting the idle (it mysteriously shot back up to 900 rpm) I happened to notice the throttle wiggle. Well, my throttle shaft is completely shot and is making it run too lean (thought the plugs looked weird |
| Author: | Aggressive Ted [ Wed Nov 04, 2009 2:46 pm ] |
Yes, you can swap base plates while your getting the original one bushed. |
| Author: | dusterguy225 [ Wed Nov 04, 2009 5:09 pm ] |
There are a few things that worry me, the BB one has a notch in one of the throttle plates and a small hole in the other. Also, three of the screws heads have broke off on them, but the bottoms are still there. |
| Page 2 of 2 | All times are UTC-07:00 |
