It is currently Sat Jun 13, 2026 6:56 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Mon Dec 07, 2009 7:49 pm
Two slants in-line under one bonnet would look something like this:
PostPosted: Mon Dec 07, 2009 8:27 pm
well i messed with the sound a little bit, and this might possibly be semi-close to the sound it will have, minus the echo-e effect..
http://members.cox.net/jdsanchez473/slant6-12.mp3
In reality it would prob. sound different, as i didn't do this in any precise manner, i have no idea how many degrees these tracks are off, i just cut a little off one track so they are offset to get a semi-sorta idea of what it could possibly sound like..
PostPosted: Mon Dec 07, 2009 8:28 pm
holy crap thats almost exactly like i pictured it, just not near as fancy :) lol
aka rusty, some holes, no hood, 12 individual pipes sicking out of the side, and a whole lot of racket
PostPosted: Mon Dec 07, 2009 9:08 pm
Oh and with help from a member of another forum i'm on quite a bit (quad4fourms.com) i've figured out how to get a really neat sound out of this setup. Take 6 cylinders, divided by 360 degrees of rotation, you get one piston firing every 60 degrees, so if you had the motors 30 degrees out of sync one way or another, there would technically be 12 individual audible fires, instead of six if they were straight up. Anyone have a sound clip of a slant 6? I'm thinking i could use audacity (sound editing program) to copy the sound file into two separate tracks and offset them to try and get an idea of what it will sound like.
That's only if it was a 2-stroke engine...........
With 4 strokes, it's 120 degrees.
So you want them 60 degrees off...........
PostPosted: Mon Dec 07, 2009 9:12 pm
It takes 2 crankshaft rotations to fire all 6 cylinders so the firing interval is 120°.
PostPosted: Mon Dec 07, 2009 9:34 pm
i can't believe i didn't think about that, actually i do lol
good thinking..
PostPosted: Mon Dec 07, 2009 10:14 pm
Also, I like the engines side-by-side. Keep the right one slanted and stand the left one up. Put big toothed pulleys like they use for blower drives on the front of both cranks, use a flywheel and empty bellhousing on one and take take the drive off the other. You'll be able to use two starters so cranking won't be a problem, both water pumps for good water flow, etc.
PostPosted: Tue Dec 08, 2009 12:36 am
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
or even slanted the other way, like a v12.
Richard (aka Fingers)
PostPosted: Tue Dec 08, 2009 4:52 am
now you have me considering this setup... i'll have to do more thinking on how to couple them. I guess i could use a big blower belt, i know they get about as much power put threw them as were dealing with here, i just wonder how long it will last, and how to pull the slack out and keep it out when you get on it.
PostPosted: Tue Dec 08, 2009 2:44 pm
If you use a big blower belt, might as well have a BIG BLOWER too.......
PostPosted: Tue Dec 08, 2009 3:19 pm
Then you can put a propeller on the front to help pull you along...
PostPosted: Tue Dec 08, 2009 11:10 pm
i think you have just made this much easier! i won't have to connect them, just have a big prop on the front engine, and the back turning the wheels, genius I tell you! lmao
PostPosted: Wed Dec 09, 2009 12:14 am
FWD and RWD, don't connect; that's too obvious.......... :oops:
PostPosted: Wed Dec 09, 2009 6:06 pm
Poser
Put em crank to crank inline Old School! Make it look sixties railish and you are good to go! Talk to some nostalgia drag guys and git er done! :D Love this post! Keep me Informed!
PostPosted: Wed Dec 09, 2009 6:47 pm
two drive lines w/ two pumkins in the rear --0-0--
Its so nice out side, I think I'll go lay under my car..
