| spark but nothing else https://slantsix.org/forum/viewtopic.php?t=38358 |
Page 2 of 2 |
| Author: | carlherrnstein [ Sun Dec 27, 2009 8:40 am ] |
the bat. voltage is 11.7 the voltage at the restistor is 11.7 the voltage after the resistor is 7 the voltage at coil is 7 i rplaced the coil put point and condenser back in i think you are right kevin i will charge the battery and see if that helps the sitiuation..................im just not shure why it was running and stalled out and died then nothing after that |
| Author: | carlherrnstein [ Tue Dec 29, 2009 4:14 pm ] |
i charged the battery hit the ignition had the classic nananoway nananoway and it started success thank you guys for all your advice |
| Page 2 of 2 | All times are UTC-08:00 |
