| My Arm is Sore... Inside Look at a SL6 Head https://slantsix.org/forum/viewtopic.php?t=38622 |
Page 2 of 3 |
| Author: | GTS225 [ Fri Jan 15, 2010 6:00 am ] |
The upper section would also have to have the rocker shaft stands as well as oiling passage(s) and the mounting surface for the valve cover. While the two-piece idea may just have merit, let's not over-simplify it. As for sealing....perhaps a groove cut into the sealing surfaces for o-ring type rubber? The stuff can be had from McMaster-Carr, and I'm sure other sources. Cut to fit where needed, a dab of silicone where the ends meet, and bolt down the top section. One may have to use something a bit better for the intake ports. Roger |
| Author: | Tim Keith [ Fri Jan 15, 2010 4:52 pm ] |
It has been done before. Using a cast billet for a CNC head is a good idea. Casting technology is now lots better than the 1960s high volume green sand production that Chrysler used. Starting with a casting that looks like a head is a good approach for saving costs as a big chunk of alloy is expensive, but scrap from junked heads is cheap. I don't know of any hobby foundries that have attempted 35 pound castings. Lost foam can be used for the water cores as foam generally works well for long and narrow castings. That's because the narrower castings have less concentrated heat, which would vaporize the foam too rapidly on a thicker casting. Foam is very accurate, you can often see a pebble grain in the finished casting. Patterns are traditionally made of wood, but you can use plastics, fiberglass or even clay for a prototype pattern. You can use a slant six head with stuff glued to it as a one-off pattern. The ports can be milled from the shaped casting. Some low volume compromise, one way or the other is probably practical. Getting a competent CNC machinist would open up possibilities. The deck might be a milled steel semi-permanent mold. Lots of possibilities with a CNC machine. It could only be a labor of live, that's for sure. Once the kinks are ironed out a few of these might be produced a month in a small shop. |
| Author: | slantzilla [ Fri Jan 15, 2010 7:40 pm ] |
Quote: Nothing a little JB weld couldn't fix!
Why not? It's been used to put together sections of a 5.7 head to make it fit a Slant. |
| Author: | Tim Keith [ Sat Jan 16, 2010 1:44 pm ] |
Doug's split OEM head would be useful in making a pattern for a stock head, maybe with changes like revised combustion chambers or raised intake ports. Thanks Doug for that. I looked at some hobby casting sites and found some interesting projects, but none so large as a head. People cast water pumps and working 1 cylinder motors, scale models of flat head Ford V8s and so forth. An amateur with a couple of helpers could do a /6 head if they had great patience and a willingness to start over again. But there is plenty of collective wisdom so that if you followed a proven path you would get good results without the headaches, but it would take a long time regardless. Once a set of prototype patterns were improved you could send these out to a production foundry. When I was very young my father worked on his cars. I saw the sand grain pattern in the castings and knew how these were made. With the parting lines, I could see where the cope and drag came to together. Because we could very carefully place the cores, an amateur casting might even be better than high volume castings from the 1960s. Craftsmen were not employed for production foundry work, workers did only what they were trained to do. Workers roles are deconstructed so that they do one task repeatedly. It is not uncommon for a entire production run to go to the scrap bin as everyone was just doing their job. A hobby shop could tweak the low buck process to achieve high quality, but at very low numbers. |
| Author: | Doctor Dodge [ Tue Jan 19, 2010 1:29 am ] |
Smart man... This "cut" was done to answer head casting questions. What we see here is what the "cope & drag" pattern and corrosponding mold halves would look like... less the draft, shrink and all the other changes needed for a "next gen" cylinder head casting. The facts remain... cylinder head sand casting are the most challenging castings out there, mostly due to the water jackets. This view of "inside the SL6 head" helps me visualize how the upper and lower water jacket cores were done (by the factory) and how they could be layed-out in an after-market head. DD |
| Author: | carsrme [ Tue Jan 19, 2010 2:46 am ] |
Hello, I think I may have posted this link before,but there is some interesting stuff in it about the mold and production process with alloy.in particular this bit Pity their interest did'nt lie with Mopar. regards,CRM |
| Author: | sandy in BC [ Tue Jan 19, 2010 8:08 am ] |
Thanks for posting these links. This is exactly the kind of information to promote better understanding of the challenges of alloy heads and blocks. Those patterns are works of art. |
| Author: | Tim Keith [ Tue Jan 19, 2010 10:22 am ] |
I've found some serious hobby casters who can pour 80 pounds of aluminum in a home shop using a home made furnace. A difficulty for a longer casting like a head is the metal would cool so rapidly (and begin to shrink) that one person could probably not pour the metal fast enough. You'd want a helper to assisting in pouring simultaneously. The lost foam technique would work for the water jackets but you have to hurry up and pour quickly. With a helper it can be done. Uneven cooling would cause shrinkage and the foam would flame out before you finished pouring. Some large risers would be needed to control shrinkage. Once you perfected the patterns and technique it would be smart to farm out production castings, but you can prototype in a home foundry. Texas State University in San Marcos has a good foundry program which I may want to pursue. It is common to use a home made waste oil burner to melt in a furnace to keep the costs down ( used motor oil ). |
| Author: | sandy in BC [ Tue Jan 19, 2010 11:21 am ] |
Wait till you see my sheet metal head.....with billet chambers welded into a CNC 1" deck. Adding tube ports and rocker stands and water jackets is just like a sheet metal intake. I suppose you could just use 5.7 hemi chambers and rockers and weld up some Firedome Valve covers...oh........wait It would cost like the Healy block....... |
| Author: | wvenable [ Tue Jan 19, 2010 3:54 pm ] |
My glass is always half full! Unless it is very good ale then eveything is off! |
| Author: | SlantSixDan [ Tue Jan 19, 2010 4:22 pm ] |
Quote: My glass is always half full!
Gee, that's unfortunate; it's much harder for an optimist than a pessimist to be pleasantly surprised! |
| Author: | Tim Keith [ Tue Jan 19, 2010 4:33 pm ] |
I want to cast some simple stuff. I think Doug's Hyper-Pak was impressive because of the length of the hollow runners. If anyone can do a head, he knows how tricky it would be. I need to learn to walk first. I've read lots of books, but no experience at all. It would be really frustrating to do a head, over and over again, without giving up on the project. I'd start with simple brackets to adapt serpentine belts, Sandem A/C brackets etc. Small castings. Maybe I can attempt an alloy L-head for my old Mopars. These run $750 or so new. Improved L-head combustion chambers are being debated similar to those used on some Harley Davidson racers, and B & S. I'd like a polished smoothie head instead of the typical ribbed flat head. An EFI /6 manifold would be good too, with six castings that bolt to a plenium rather than one big casting, probably five as the two center runners can be paired. The hobby castng gurus say a large head casting is possible in a home shop but casting porosity would be a concern to overcome. A pro foundry could deal with that as its a text book problem for them. We have to create good quality patterns that a foundry would not laugh at ! I also want to do iron. Iron is probably better for A/C brackets because alloy can crack when not heated treated properly. But iron melts at almost 3 times the heat as aluminum. |
| Author: | wvenable [ Tue Jan 19, 2010 5:42 pm ] |
Dan, I really like my rose colored glasses. |
| Author: | carsrme [ Tue Jan 19, 2010 6:18 pm ] |
hello,brackets because alloy can crack when not heated treated properly. But iron melts at almost 3 times the heat as aluminum. have you thought about using this stuff for small quantities of molten iron? this is a copy of a post on Inliners from a while ago. Originally Posted By: Nexxussian That's more than I knew when I asked. Thank You. For me, I have a couple projects I would like to try in Aluminum, and a couple more in Iron. The last two are the ones I figure will be the most difficult (because it's Iron). I figure I could cast simple Aluminum parts like covers and what not here. I would be hard pressed to generate the heat (BTU's not just degrees) it would take to melt the Iron. hello, you might try this stuff to melt/supply iron for your casting job. once lit,it is self sustaining and gets REAL hot. a couple of links for your information. http://www.youtube.com/watch?v=nR6K90cR8Lg http://en.wikipedia.org/wiki/Thermite if your job only needs small amounts of iron to cast,this may help. cheers,CRM |
| Author: | Tim Keith [ Tue Jan 19, 2010 6:42 pm ] |
Successful grey iron casting has some technical issues, such as carbon and silicon content. Iron will melt very well with a waste oil furnace, or propane. Traditionally coke or charcoal is burned in a cupola but I have been unable to source any foundry coke in South Texas. If you live in some cities in the northeast you can sometimes find plenty of coke at rail road grade crossing when the stuff bounces out of open cars. Shipping a couple tons of coke is a killer these days. Waste oil is free, or very cheap. Some use electricity to power the furnace, it has less fumes so that you can melt alloy in a basement shop. Nobody that I know can make steel at home, but grey iron is commonly melted in backyards. At 2600F to melt iron there is an extra safety concern contrasted with 900+F for aluminum, which you can melt in a open camp fire. You can suffer serious injuries as the hot metal will explode with contact to moisture. Iron with incorrect silicon or carbon can be very brittle and break easily, but aluminum is basically what your scrap was. You can build much of the foundry equipment yourself. Or purchase from a company like this : http://www.mifco.com/index.htm |
| Page 2 of 3 | All times are UTC-07:00 |
