| Triple one barrel setup? https://slantsix.org/forum/viewtopic.php?t=38764 |
Page 2 of 4 |
| Author: | 2 Darts [ Mon Jan 25, 2010 10:32 pm ] |
Neat idea to try it with domestic products. It has been done before quite successfully on the Jaguar XKE. These had 3 1 bbl SU carbs. It was a thing of beauty. ![]() ![]() The SU was a side draft, constant velocity carb. They were difficult to synchronize. Your solution of a plenum with the carbs operating on a progressive linkage gets around the carb sync problem. |
| Author: | carpdar [ Mon Jan 25, 2010 11:08 pm ] |
I like Karasik87's approach.. you could get it milled flat on that side and get studs installed for the other "manifold". There's aftermarket 3 carb manifolds for the slant, but doubles are easier to come by from what I've seen. btw I got my 64 valiant when i was 15 and been driving it everyday since |
| Author: | Kevin Johnson [ Tue Jan 26, 2010 3:17 am ] |
A friend gave me a triple glass bowl Holley setup for a Ford six a long time ago. I think it was an Edelbrock. Cool looking. I have a slant six Benelli Sei motorcycle. It came with triple carbs and six into six exhausts. I bought a six into six carb setup made from Honda 500 manifolds, which engine the Benelli was based off of. Sounds real mean like a Ferrari or something. Go for it. |
| Author: | /6 Matt [ Tue Jan 26, 2010 4:35 am ] |
Quote: I bet you could do this with a stock intake manifold.
Dude you are the man, you just gave me the sweetest Idea. I think I know where the intake can be grinded down. If I weld a plate on there that will allow me to bolt a plenum to it with a gasket in between the two. The I can make a box shaped plenum to bolt up to it, and if the plenum needs to be adjusted then I can simply unbolt the plenum and make a new one to weld up to the intake.
| Author: | 66aCUDA [ Tue Jan 26, 2010 6:47 am ] |
Hummm Tuba. That what I played. We have a Band teacher on the board here His name is Greg Ondayko you may want to pick his brain about Music teacher prospects. If you can get your college paid for do that. Auto mechanics can be done on a certificate program. JMHO Frank |
| Author: | Fopar [ Tue Jan 26, 2010 8:22 am ] |
This is a picture of my engine.
| Author: | /6 Matt [ Tue Jan 26, 2010 3:03 pm ] |
well change of plans, i seem to have come down with something so the picture might be a ways off. postint through the interweb on my phone. |
| Author: | adiffrentcity [ Tue Jan 26, 2010 5:05 pm ] |
I've seen Flanges to build your own intake maifolds on ebay pretty regularly. Cheap too. The Idea of modding a manifold for studs and bolting on a "log" of your design might be the best way though. I think the others are correct in that everything will be easier to do if you get the three carbs bolted to a plate so that you know how much room you need and you will have the linkages etc, already working. Good luck! Show us results! |
| Author: | ESP47 [ Tue Jan 26, 2010 7:28 pm ] |
Quote: I like your 3 carb idea. I have thought about it a few times, but time and money always get in the way.
You working at shops or at dealerships? Most of the guys at my dealership bring in between $80-100k+ and they get there by bouncing from dealership to dealership every few years while having a nice bump in pay to go along with it.
On a side note, turning wrenches is a fun hobby, a really fun hobby, BUT doing it for the general public, every day, is no way to make a living. I have been doing it for 23 years, made several attempts to get out but always fell back in. What other profession do you get to spend 25% of your take home pay just to stay current? Good luck, and lets see some pics when them 3 carbs are up and running. TopHat |
| Author: | /6 Matt [ Wed Jan 27, 2010 3:32 am ] |
Quote: This is a picture of my engine.
What kind of fuel economy are you gettin in that thing, cause you'r runnin a six pack all the time right, no primary/secondary setup like I'm talkin. Also, what kind of cam are you runnin in that thing?
| Author: | /6 Matt [ Wed Jan 27, 2010 3:34 am ] |
Does a super six have bigger runners on than the one barrel intake? Or does it simply have another throttle bore in the top of the plenum? I suppose I could grind down the inside of the runners for better flow. |
| Author: | Fopar [ Wed Jan 27, 2010 10:39 am ] |
Mileage with 2.80 rear gears 21.98 highway -- 16.28 around town Mileage with 3.80 rear gears 18.75 highway -- have not checked around town. Have a custom ground cam, this is in a 63 Dart GT Super six manifolds have a 2 equal sized holes. |
| Author: | /6 Matt [ Wed Jan 27, 2010 2:03 pm ] |
Attention!!! Does anybody off the top of their heads know the diameter of the throttle bore on the one barrel manifold, or do you have a manifold to measure from? I'm drawing a scale picture now and need a measurement, not precision, just using a ruler is fine with me. |
| Author: | Fopar [ Wed Jan 27, 2010 3:28 pm ] |
Measures 1 5/8" |
| Author: | /6 Matt [ Wed Jan 27, 2010 3:35 pm ] |
Quote: Measures 1 5/8"
thanks alot man, I appreciate it. Ishould have a photo coming soon |
| Page 2 of 4 | All times are UTC-07:00 |
