| Old Fel Pro head gasket https://slantsix.org/forum/viewtopic.php?t=39055 |
Page 2 of 2 |
| Author: | Dart270 [ Wed Feb 24, 2010 3:25 am ] |
OK, fast may you ride... Lou |
| Author: | Charrlie_S [ Wed Feb 24, 2010 5:18 am ] |
When I put my turbo motor together, using a copper head gasket, I used Hylomar in a spray can on the gasket. First time using the copper gasket. It was together for about 3 years with absolutly zero coolant or oil seepage. Got the Hylomar from either NAPA, or Carquest. I like it. |
| Author: | terrylittlejohn [ Wed Feb 24, 2010 3:20 pm ] |
charlie is that the same as the spray/ adhesive you can get at the chrysler dealer, they use it on the 2.0l steel head gaskets, thats is what i used on my copper gasket with no problems. |
| Author: | darrt wells [ Wed Feb 24, 2010 3:54 pm ] |
Quote: Will be torqueing to 65 lbs not 85 like I thought.We will see.Mark
What is your reasoning behind that? Owen |
| Author: | madmax/6 [ Wed Feb 24, 2010 5:26 pm ] |
7/16 Arp studs recomend 62lbs.Wonder how much more I could go.Guzzi Mark |
| Author: | Shaker223 [ Wed Feb 24, 2010 5:47 pm ] |
Quote: 7/16 Arp studs recomend 62lbs.Wonder how much more I could go.Guzzi Mark
My directions say:70lbs w/arp moly lube 85lbs w/30wt oil 65lbs w/aluminum block and moly lube. |
| Author: | slantzilla [ Wed Feb 24, 2010 6:35 pm ] |
I was at the Chicago Connection tonight. Bill stocks Hylomar in the spray can there. |
| Author: | Shaker223 [ Wed Feb 24, 2010 7:00 pm ] |
Quote: When I put my turbo motor together, using a copper head gasket, I used Hylomar in a spray can on the gasket. First time using the copper gasket. It was together for about 3 years with absolutly zero coolant or oil seepage. Got the Hylomar from either NAPA, or Carquest. I like it.
I used Hylomar on my copper head gasket as well. Nice stuff. Found a bunch at a local swap meet for $3/can/tube. Bought a bunch |
| Page 2 of 2 | All times are UTC-07:00 |
