PCV Valve won't come out of Valve Cover?
https://slantsix.org/forum/viewtopic.php?t=39236
Page 2 of 2
Author:  Stante [ Sat Mar 27, 2010 10:37 am ]
Success! Was able to get the PCV chimney off the valve cover. Any Idea where to get a new PCV Valve? this one is installed from the bottom of the chimney and hex nut holds it in place from the top. Any suggestions on where I could find a replacement PCV valve like this all metal one? Thanks for ALL the help......
Author:  SlantSixDan [ Sat Mar 27, 2010 11:54 am ]
Old Car Parts Northwest has the metal PCV valves. Or, faster and cheaper, see here. If you buy a current-production PCV valve, try an ACDelco CV761C, a Standard V165, or a Chrysler 5175 351AA.
Author:  Stante [ Sat Mar 27, 2010 2:29 pm ]
Dan, you're the BEST! New Standard 165 PCV Valve installed, with Dorman 42056 GM grommet on inside of "chimney" and was able to get spring installed too. Nice snug fit. Amazing how loose the chimney is now compared to rusted on. It comes off as easy as the breather cap. Thanks for all your help.
Page 2 of 2 All times are UTC-08:00
