| Roller cams.... https://slantsix.org/forum/viewtopic.php?t=39589 |
Page 2 of 3 |
| Author: | CNC-Dude [ Sun Mar 28, 2010 11:59 am ] |
Its quite possible that a gear made of the same material could work out in the long term. Can someone post some pics of this gear please. Thanks |
| Author: | sandy in BC [ Sun Mar 28, 2010 12:30 pm ] |
http://www.slantsix.org/articles/oil-pu ... report.htm |
| Author: | sandy in BC [ Sun Mar 28, 2010 12:32 pm ] |
Just put a Chev gear pattern on the cam ........or Ford...or.... Then we can buy pump gears from Summit. |
| Author: | Fopar [ Sun Mar 28, 2010 1:44 pm ] |
Ford or Chev gear will not work. Both have gear OD's of 1.245" and slant 6 oil pump housing is 1.125" or TOO BIG to fit in the block hole. |
| Author: | CNC-Dude [ Sun Mar 28, 2010 2:37 pm ] |
Quote: http://www.slantsix.org/articles/oil-pump-gear/failure-fix-report.htm Thanks for the link. One thing that I have personally experienced with race engines that use flat tappets and high volume pumps, is that any time you have excessive distributor gear wear, it usually can be traced back to too much cam walk, or improper gera meshing. On many of the dirt track engines I have built, the RPM's are up to about 8500 down the straights, and decelerated to maybe as low as 4000 RPM in the turns for 50-75 laps, and will last 3-4 racing seasons just fine without excessive wear. With engines that use timing chains, the cams natural tendency to try and come out the front of the engine really works on the distributor if it isn't retained with a thrust button or thrust plate.
| Author: | /6 Matt [ Sun Mar 28, 2010 7:35 pm ] |
Quote: $650-$675 range On to my second question of the thread: What kinds of grinds will you be offering? Street, strip, both? |
| Author: | /6 Matt [ Sun Mar 28, 2010 7:37 pm ] |
Quote: Ford or Chev gear will not work. Both have gear OD's of 1.245" and slant 6 oil pump housing is 1.125" or TOO BIG to fit in the block hole. I'm assuming that means it's not possible to machine the hole in the block .120"?
| Author: | CNC-Dude [ Sun Mar 28, 2010 7:49 pm ] |
Quote: Quote: $650-$675 range On to my second question of the thread: What kinds of grinds will you be offering? Street, strip, both? |
| Author: | Fopar [ Sun Mar 28, 2010 8:20 pm ] |
Responce to boring hole bigger-- the center line of the pump would be in the same place. But the gear on the cam would have to be smaller than it is now to make it work |
| Author: | CNC-Dude [ Sun Mar 28, 2010 8:46 pm ] |
Dartman, forgot to answer your second question. I am planning to offer profiles for street, strip and all out race applications if needed. |
| Author: | DusterIdiot [ Sun Mar 28, 2010 9:09 pm ] |
| Post subject: | And... |
Quote: Wow... that's alot of money. Not saying that isn't a competitive price. I guess this is something else to add to my list of things to save for. By the way (on to question #3) is this forseen price range for a cam or for the complete kit?
Considering the Cox Brother's Cam blank was $1000-$1200 + you send it to a cam grinder... and you are still in it at $400+ for lifters...$650+grinding+ lifters isn't a bad thing...What kind of base circle are you planning to start with? 0.4"? -D.Idiot |
| Author: | CNC-Dude [ Mon Mar 29, 2010 9:09 am ] |
| Post subject: | Re: And... |
Quote: Quote: Wow... that's alot of money. Not saying that isn't a competitive price. I guess this is something else to add to my list of things to save for. By the way (on to question #3) is this forseen price range for a cam or for the complete kit?
| Author: | Fopar [ Mon Mar 29, 2010 9:38 am ] |
Quote: Its quite possible that a gear made of the same material could work out in the long term. Can someone post some pics of this gear please. Thanks
Any way you could do the oil pump gear? The dist. gear is some sort of plastic already and doesn't seem to cause any real problems.
| Author: | CNC-Dude [ Mon Mar 29, 2010 9:52 am ] |
Sure, I'll be glad to look into it and see what can be done to improve the longevity of it. |
| Author: | Doc [ Mon Mar 29, 2010 4:47 pm ] |
I have made the oil pump drive gears out of C630 bronze alloy and those hold-up well. (aluminum nickel bronze) I actually have one in my daily driver street car and it has been fine. (about 8000 miles on it so far) Making these gears is pretty easy. DD
| Page 2 of 3 | All times are UTC-08:00 |
