It is currently Mon Nov 16, 2026 9:46 am
PostPosted: Sun Jun 06, 2010 5:16 am
You need to check amperage not voltage - re read my earlier post to effectively test for current draw while the car is idle (not running) - it is merely a check as it sounds like you have found the problem :)
The car I am restoring is a 1971 Valiant 4 door with a slant 6 - 225 engine.
PostPosted: Tue Jun 08, 2010 9:56 am
I ran a check Sunday using amps and couldn't get a reading at all. I had it connected in series to the negative battery post and the ground cable. I take it that means there is no more draw and the car should be ok, right?
PostPosted: Tue Jun 08, 2010 2:34 pm
Si :)
