Battery being drained while key is off
https://slantsix.org/forum/viewtopic.php?t=39965
Page 2 of 2
Author:  Mark Mallett [ Sun Jun 06, 2010 5:16 am ]
You need to check amperage not voltage - re read my earlier post to effectively test for current draw while the car is idle (not running) - it is merely a check as it sounds like you have found the problem :)
Author:  ESP47 [ Tue Jun 08, 2010 9:56 am ]
I ran a check Sunday using amps and couldn't get a reading at all. I had it connected in series to the negative battery post and the ground cable. I take it that means there is no more draw and the car should be ok, right?
Author:  Mark Mallett [ Tue Jun 08, 2010 2:34 pm ]
Si :)
Page 2 of 2 All times are UTC-07:00
