Parasitic battery drain
https://slantsix.org/forum/viewtopic.php?t=40638
Page 2 of 2
Author:  shadetree [ Wed Aug 18, 2010 11:29 am ]
Post subject:  oddball electric shorts
All you gues are right. But heres the reason key off shorts occur
even in nonopowered wires. Electricity flows from negative to positive
it is a potental not an actual flow.So if your wire is grounded you
have a problem. If you want a LOT of FUN try ground shorts.
They will drive you NUTS. I really do like electrical work.But then
I am sort of strange. cr
Author:  Chuck [ Thu Aug 19, 2010 1:53 pm ]
Post subject:  Re: oddball electric shorts
Electricity "flows" when there is "current". Your battery provides the "potential" to flow current. Current does not flow in wires that are not connected to a battery (potential). Let's not confuse our readers more than they already are.
Page 2 of 2 All times are UTC-07:00
