| cliffy intake gap ?? https://slantsix.org/forum/viewtopic.php?t=40862 |
Page 2 of 3 |
| Author: | Volare4life [ Fri Jul 02, 2010 11:54 pm ] |
its appreciated DI but i got it covered, little sheet metal, some jb weld, 2 intake/exhaust mani studs 2 nuts and one misc bolt, 2 spacers ( one was from a chunk out of long spacer for my rear sway bar end links, the other was a 5/16 tube nut) ![]() ![]() ![]() -Mike |
| Author: | Sam Powell [ Sat Jul 03, 2010 4:52 am ] |
Does your set up include heated air for the air cleaner?. This will help with cold drivarbility. I think it is a part that bolted onto and around the stock exhaust manifold. I think your block off plate is a good start, but honestly is too thin to last. It is so much trouble to take off that intake exhaust/combo, I would encourage you to take your sheet metal plate to a machinist, or metal worker and have a 1/4" plate made as Joshua recommended. It will save you much time in the long run. Your back will thank you for it. Good luck, Sam |
| Author: | 66aCUDA [ Sat Jul 03, 2010 5:56 am ] |
Also a quick note. Watch out using Galvinized metal. The burning product can kill you. Just my 02. Frank |
| Author: | DusterIdiot [ Sat Jul 03, 2010 8:05 am ] |
| Post subject: | Yep... |
The fire rating for that thin of sheet metal is about 1-2 hours...The fumes from heated galvinized( the zinc) will make you sick and send you to the hospital (in my trade you have to wear a filter mask and a welding hood to weld on it). From previous experience with bolting on plates to use with the Dutra split manifold I would shoot for 3/16" plate, and if you mix is OK you can use the Bronze RTV...JB weld I think holds up to about 300-350 degrees (exhaust is in the 4-500 range if tuned...and up to 1000 if you are reallly lean). -D.Idiot |
| Author: | Volare4life [ Sat Jul 03, 2010 12:59 pm ] |
well i know about the fumes from galvinized steel, but this is just a patch, I have header flanges (off ebay) on order, I have a buddy of mine swinging by today and I will got get raped at home depot for some sheet steel, it was me just seeing if it #1 i could do it, and #2 if it might survive engine break in, but i will fix it once i get my sheet steel. now what kind of mounting spacer is need to go between the cliffy intake and my eddy carb ?? -Mike |
| Author: | maxracer21 [ Sat Jul 03, 2010 5:24 pm ] |
THAT'S WHERE YOU WANT TO USE THE WOOD.........BEST INSULATOR AND ITS FREE ALMOST Max |
| Author: | Volare4life [ Sun Jul 04, 2010 3:41 pm ] |
working on a 2" spacer as we speak (i know kinda thick but the wood was free lol) since my cliffy came with no carb adapter I got to engineer one !! also I have a edelbrock 1405 series carb (it was also free http://www.edelbrock.com/automotive_new ... 0/1477.pdf and can i make all 4 barrels open at once VS front 2 then at half throttle rear 2 begin to open ?? -Mike |
| Author: | Volare4life [ Sun Jul 04, 2010 5:23 pm ] |
update heres my carb spacer, total time to make 1.5hours ( most of which was drying time for the glue) ![]() -Mike |
| Author: | maxracer21 [ Sun Jul 04, 2010 5:41 pm ] |
Be sure to use a gasket on each side..........I've been doing these wood spacers for years and they always work perfectly. I even ran a 9:93 with wooden spacers on a tunnel ram. I'm old school, really old school. I'm surprised someone hasn't tried to tell you differently. Make sure it's flat! MaX |
| Author: | Wesola78 [ Sun Jul 04, 2010 6:20 pm ] |
I like that spacer! |
| Author: | maxracer21 [ Sun Jul 04, 2010 6:27 pm ] |
Now he has the makings of a REAL hot rodder. No parts changer at home here........... MaX |
| Author: | Volare4life [ Sun Jul 04, 2010 8:02 pm ] |
cheapest spacer i could find THAT WOULD work but still need to be modded-------$29 (1"alum) mine--- 2" wood with the correct bolt patterns (wood was free $4 for the 5min epoxy) total $4 Free edelbrock 600cfm carb carb rebuild kit w/free marine accelerator pump seal $21 getting it running before i die...... PRICELESS lol -Mike |
| Author: | Volare4life [ Mon Jul 05, 2010 9:49 am ] |
UPDATESSS !!!! well i had to stop started messing stuff up oh yea it ws also 630 in the morning.......... i started working on her at 6pm an and off till about 8pm then hard charged throught the rest, ![]() ![]() ![]() ![]() ![]() ![]() now off to finish her, -mike |
| Author: | maxracer21 [ Mon Jul 05, 2010 11:09 am ] |
looks like it'll work .................now for a nap eh? regards, MaX |
| Author: | Volare4life [ Mon Jul 05, 2010 12:00 pm ] |
i got about 5 hours, could hardly sleep so close to done its scary lol -Mike |
| Page 2 of 3 | All times are UTC-07:00 |
