New timing chain too long/loose. Is there another chain size
https://slantsix.org/forum/viewtopic.php?t=40883
Page 2 of 2
Author:  Old6rodder [ Fri Jul 30, 2010 11:52 am ]
if you put a small gear on cam and not a smaller on crank....you have changed ratio .... as engine turns it will change cam timing...wont work
I just read this thread and was wondering when someone'd get around to mentioning the basics, that a tooth count of 2 to 1 is requisite. A 50 tooth cam sprocket'd need a 25 crank, and a 48'd need a 24.
Author:  volaredon [ Sat Jul 31, 2010 7:01 am ]
You mention that you were gettin Cloyes chains; I ran into that same problem a few years ago buying Cloyes T chains for a 318. I went thru a couple of them; both too sloppy for my liking; so I returned the 2nd one to Useless Zone then went around the corner some place else, and bought an Edelbrock, double roller as the Cloyes units were.
The Edelbrock was a much better fit.
I'd used Cloyes parts before but like every other manufacturing company these days "they don't make em like they used to".
the particular Cloyes chains I had bought weren't the "performance" ones but rather a "factory heavyduty replacement" meaning it was meant for the cop cars and other "premium" smallblocks that originally came with a double roller.
Author:  Rick Covalt [ Sat Dec 12, 2020 2:01 pm ]
Post subject:  Re: New timing chain too long/loose. Is there another chain size
Wow! I just saw this in my searching! Has anyone else seen this different tooth count set? Doesn't look like the poster ever followed up.
Having problems with a set in my truck. Although I am not at all sure I want an odd ball set installed for the future.
Author:  matv91 [ Sun Dec 13, 2020 6:06 am ]
http://www.romacusa.com/products.html
Author:  matv91 [ Sun Dec 13, 2020 6:11 am ]
http://www.romacusa.com/tech_timing_sets.html
Author:  matv91 [ Sun Dec 13, 2020 6:18 am ]
http://www.romacusa.com/downloads/Sprocket_DataUS.pdf
Author:  matv91 [ Sun Dec 13, 2020 6:21 am ]
measure center to center ,data in pdf 5.125
Author:  matv91 [ Sun Dec 13, 2020 7:14 am ]
https://www.slantsix.org/forum/viewtopic.php?t=24900
Author:  Docmcg [ Sun Dec 13, 2020 2:38 pm ]
Getting close to putting my /6 back together. How much timing chain slack is “too much”?
Author:  Greg Ondayko [ Mon Dec 14, 2020 7:23 am ]
Then there's a soultion that this guy is trying:
https://www.slantsix.org/forum/viewtopi ... &start=216
and this guy:
https://www.forabodiesonly.com/mopar/th ... nt.432795/
Page 2 of 2 All times are UTC-08:00
